Great deep sky night
Started by Inge_S, 03/11/2004 07:16AM
Posted 03/11/2004 07:16AM Opening Post
I spent 4 hours last night with my 12.5-inch Portaball at a dark sky site. There was some glow from a city in the south east, and seeing could have been better. Therefore I spent little time with the planets and observed just a few double stars.
Equipped with a 24mm Erfle and an O-III filter I had my first really good view of the Rosette nebula. The amount of detail was impressive. The northern part of the annulus was brightest, but nuch more irregular in the outline than I have seen with my smaller scope. Many dark lanes and patches could be seen. An impressive sight.
While in Monoceros I also observed NGC2261. At high power (214x) the nebula appeared large and bright with definite signs of the darker regions that can be seen in photos.
Another very attractive gaseous nebula in this region is NGC2245. It looks like a small comet with a tiny bright core (probably a star). Didn't use the O-III for the two last objects.
Encouraged by the success I went for the Medusa nebula (PK205+14.1). A nearby cluster (NGC2935, not impressive) was easy to spot. A small distance to the east a faint glow could be perceived without the filter. For this nebula the O-III worked like magic. The planetary stood clearly out, half moon shaped with the upper and lower part definitely brighter than the middle.
A small part of the supernova remant, IC443 could be seen with direct vision with the O-III. This object is far more difficult than the medusa nebula.
I observed many galaxies. Both M51 and M101 showed nice spiral structure. I find the spiral arms of M101 to be easier to detect visually than those of M81. Unfortunately the city light made scrutiny of M99 and M100 impossible. Have to wait for a dark night.
NGC4236 is considered to be difficult, but it was readily seen under yesterday's conditions. Huge, elongated and impressive. On the opposite end of the scale was NGC3115 in Sextans which appeared tiny and very bright.
Most distant view was the pair NGC4874 and 4889 in the Coma cluster. They appeared quite large and bright, and a lot of fainter spots and smudges call for my attention on a later occasion when the galaxy cluster is higher in the sky.
