Last observing night - until August
Started by Inge_S, 04/27/2005 06:16AM
Posted 04/27/2005 06:16AM Opening Post
The period of nocturnal darkness is drawing to an end here in the high north, and it is time to put the scope away for the summer season. Yesterday night was clear, and I decided to sacrifice som hours of sleep to have a galaxy observing session with my 12.5-inch Portaball. Seeing wasn't excellent, and the sky in the north was still bright when I started observing at 11:45 pm. Therefore I used the first 30 minutes to teach a friend how to locate a couple of objects. From about 00:30 until the moon came up an hour later, the sky was dark enough for some decent deep-sky work. Totally I logged 58 galaxies this night. I spent some minutes galaxy hopping with a 13mm Nagler in the central part of the Virgo cluster, and just along the chain between M84 to M88 I found 18 galaxies. Afterwards I made a stroll through M87 with its satelites, down to the Siamese twins.
After a period of observing just moderately bright galaxies, I spent some time on the large spirals in Canes Venatici and Ursa Major. With this aperture M51 clearly shows its spiral structure at 63x magnification. More detail is, however, seen with higher power. M101 is great with the 13mm Nagler. I consider it to be the most appealing of the spiral galaxies within reach of my scope. This time I also located a group of neighbours to M101. The galaxies, NGC5473, 5422, 5443, 5475 and 5485 are almost arranged in a circle. None of them are impressive, but are easily found, and will probably be within range for smaller scopes.
After a new period of fuzzyball viewing, I turned to M106 which is an awesome galaxy, impressive in size and brightness, but not showing any appreciable spiral pattern. It has two neighbours, NGC4346 and 4271 (possibly line of sight coincidence), both much smaller, but with high surface brightness. In particular I found 4271 very appealing, being so different from the large galaxy.
Another very bright galaxy in the region is NGC4449. Yesterday night I saw it for the first time in the 12.5-inch and I was really impressed. A much smaller galaxy, NGC4460 is located nearby.
I also observed some globular clusters, all being old friends. M13, of course, and M5, which I don't observe so often. M53 is still fainter, but it is well resolved. Some effort was needed to spot the "ghost" of M53, NGC5053. Now the moon started interfering, and the sky background was affected. At 115x power, however, I could see individual stars in 5053.
I also observed a pair of calaxies in Draco, NGC4291 and NGC4319. They are fuzzyballs in the 12.5-inch, but I tried to use them as a guide to the distant quasar, Markarian 205. However, the sky wasn't dark enough for me to spot this faint starlike object.
Inge S
Posted 04/27/2005 10:28AM #1
Inge, thanks for the report!
I was also out yesterday; but instead of 60 galaxies I stared in awe at a few selected Messier objects since it was one of the first eight inch sessions for me. Right after the sunset I (together with my friend) looked at some open clusters (M35 and on). It was too light yet when I looked at M101 (it was huge and bright nevertheless) and I couldn't make out the spiral structure, but I saw it in M51 later on with some difficulty. M57 was just as on a (black and white) photo. M13 and M3 were awe-inspiring (I forgot about M5, perhaps tonight). Then there were the Messier and some NGC galaxies in Leo and "the face" composed of M84/M86/4387/4388, after which we were too cold and tired to continue. There are still two or three dark nights to go since I am located farther South!
Dmitri
Posted 04/27/2005 04:48PM #2
Inge,
Its amazing how many objects you are able to find in a few hours or so.
It is also amazing, that you have clouds for three months during the winter then daylight from what, May 1 until August 1? And auroras when the sky is dark!
You certainly make the most of your time available, I really enjoy all of your observation reports.
Catch a lot of fish! 8)
Rick W
8" Zhumell Dob
90mm f11 achro refractor
Posted 04/28/2005 03:09PM | Edited 04/28/2005 03:23PM #3
Hi Inge,
Well now that you have a lot of time on your hands and Herb seems to be creating Forum Managers......are you interested? Maybe the Double Star Forum instead?
I have always enjoyed and respected your insights and even-handed comments. You have not only interest in observing, but also the physics of double stars. (That's about as heavy as I can lather on the encouragement!)
How about it?
Pete
Posted 04/30/2005 03:44AM #4
Inge:
I recall your post at this time last year, saying goodbye to dark skies, and can't help but see this as a bit poignant. I enjoy reading your reports--thanks for them and the ones to come.
Cheers,
Bill Travis
Posted 05/04/2005 11:23PM #5
I've just had a DSO observing session in my back yard; the sky is still dark to see some amazing things. M105 and NGC3384 in the SW were drowned in the light dome of Gothenburg - I saw only the star-like cores surrounded by faint halos, but the sky in the South was decent. I saw the black patch in M64 clearly at high power. Unfortunately, M104 was behind the roof. I could also see mottling in NGC4631 and just glimpsed with averted vision the dark lane in NGC4565 - both with 12.5mm. After that came the clouds.
I am extremely happy with my new C8! Go-to is irreproachable, and eight inches of aperture make a huge difference to the views with 80mm.
I still hope to get at least one session before it becomes too light at night - if the weather allows.
Dmitri
