Limiting magnitude under less than perfect cond.
Started by Inge_S, 10/14/2005 10:13AM
Posted 10/14/2005 10:13AM Opening Post
Yesterday evening I made an observation that surprised me a bit. I went outside an hour or so after sunset. The sky background was still far from dark (dusk always lasts long at my latitude) but stars down to about 5th magnitude were readily visible. The moon was still very low and didn't contribute much.
Three hours later the influence of the sun, of course, was gone, but the moon was higher in the sky. At this time the sky appeared black, not blue, but the faintest stars were no longer visible. The limiting magnitude was now about 4.
I'm a bit puzzled about this. Why could I see more stars on the relatively light blue background at dusk than at the black bacground of the moonlit sky later at night? Was I somehow fooled by my dark adaptation? Is there a difference between sunlight scattered by the upper atmosphere and moonlight scattered by the lower? How important is the ambient light from the moonlit landscape?
If this was the only time I made this observation, I would hardly have mentioned it. But this seems to be a common phenomenon. Have anyone else made the same observation? Any idea why it is like this?
Inge S
Posted 10/14/2005 01:07PM #1
Inge,
I have had this same experience twice during the past few months. The night begins with very promising clarity, then deteriorates as the time passes. By midnight, I was only able to see 4th mag stars. I don't think it was my night vision adaptation. The loss of magnitudes due to the moon rising is much faster - here at least.
Perhaps it was due to water vapor in the air, condensing into a very slight fog or cloud.
8" Zhumell Dob
90mm f11 achro refractor
