M106 and its negihbours
Started by Inge_S, 04/16/2007 07:04AM
Posted 04/16/2007 07:04AM Opening Post
Last Friday we had excellent conditions for deep-sky observation. I'll not give a complete observation report from the observing session right away, but as a start tell about my observation of M106 (NGC4258) and nearby galaxies with my 12.5-inch.
M106 itself is one of the greates galaxies in Canes Venatici, comparable in brightness to M51, but not so interesting visually. Within a radius of 2 degrees several fainter galaxies can be found - most of them are faint fuzzyballs, but I still find the region interesting to explore.
Very near the large galaxy lies NGC4248. This galaxy is small and faint, but since it is highly elongated it isn't too difficult to spot. A bit further away in the same direction a pair of very small and faint patches of light are located. This is galaxy pair NGC 4231/32. If I didn't know the exact position of these objects, I would not be able to recognise them as galaxies.
Further away from M106 three slightly brighter galaxies can be observed; NGC4346, NGC4220 and NGC4271. Most observers with sufficient aperture will immediately see the two first ones. NGC4271, on the other hand, is likely to go undetected, although it is similar in total brightness to the other two objects. The main reason for this is a group of relatively bright foreground stars.
None of these objects are showpieces. They may be interesting, though, for the observer who wants to check his/her ability to detect faint galaxies visually.
Inge S
Posted 04/17/2007 03:32AM #1
Inge,
Oddly enough, I have observed 108 of the 109 Messier objects (not counting M102), and M106 is the one I am missing. I am sure I will pick it up in the next few weeks. Your comment that it has similar brightness to M51 is encouraging, I am able to see M51 and its partner easily.
Tonight I worked around the realm of galaxies in Virgo/Coma and viewed all the Messiers, also the five in Leo. Plus a few NGCs.
My eyes became tired, so I found globular M53 in Coma and finally aimed at beautiful Saturn. I hope you have clear skies and can enjoy your few weeks of remaining dark nights, Inge.
Regards,
Rick Wiseman
8" Zhumell Dob
90mm f11 achro refractor
