Last night I made a few observations from one of my local dark sites. It cleared up late at night and the wind was a bit stiff, but I decided to make a short observing session.
Seeing was good in spite of the wind. Using a 9mm Nagler (167x) the companion of Theta Aurigae was well separated from the glare of the primary, and a very nice, clean split of 57 Cancri was achieved. Double star observation at higher power was, however, hopeless, since the wind affected the telescope.
I spent some time hunting for 12th magnitude fuzzyballs (found quite a few, including NGC4889/4874 in the distant Coma cluster), before turning to the brighter galaxies. Light conditions were fair, but not excellent. High air humidity and a pretty bright aurora were disturbing factors. I used the 9mm nagler to make out detail in M51, M101 and the M81/82 pair. This evening I made out some of the emission nebulae in M101, and the spiral pattern of M51 was quite prominent (obvious also at 63x). I noticed another faint galaxy not far from M51/5195, presumably NGC5198.
The highlight of the session, however, was M81 located near zenith. At 167x the galaxy filled out much of the field of view, including the two foreground Struve doubles, both of which were delicately resolved. The spiral arms were most easily seen with averted vision, but could even be traced with direct vision. Moving from 12-th magnitude galaxies directly up to one which is 100 times brighter is pretty effectful.
M82 was also very rich in detail, with many dust bands visible. I'm always impressed by the surface brightness of this galaxy, but last night I found it particularly striking.
Inge S
Inge S
