Hello:
On Monday night Josh Walawender and I attempted the Messier Marathon from the 11,000 ft. level of Mauna Loa, Hawaii. The night was clear, with little wind and the temperature was a little above freezing. Our southern latitude (+20) changes the search order early in the night a bit. M52 and M103 are the first objects that must be found since M77 and M74 aren't that low in the sky once it gets dark. We also get a lot of the Scorpius and Ophiuchus objects before the targets in Cygnus are visible. Since we're so far south, M30 was visible just at the start of twilight while the sky was still dark. I was able to observe all 110 objects with a 12.5" dob, while Josh (observing with a 4" and 80mm Stellarvue refractors) only missed M74 due to an antenna mast with lights on it being along the line of sight to M74. M74 was also the most difficult object for me, with M110 also being quite tough. This was my second full attempt at the Messier Marathon, and first time I got them all. Has anyone done the Messier Marathon from a latitude farther south than Hawaii?
Cheers
Mike Connelley
Cheers
Mike Connelley
