Hello:
During tonight's star party, the seeing was quite good, so I decided to try to split Antares with my 12.5" cassegrain. The scope did this without too much trouble. While observing Antares at about 375x, I noticed what appeared to be a nebula near Antares. I have split Antares before, and have not noticed this. It was about 1/4 of a field of view away from Antares, which would be 2' to the NNW. It's shape was a bit like a comet, with a "head" to the south and a short faint "tail" to the north bending to the west, the whole this being about 0.5' long. It would say that it looked about as big and bright as a 10th magnitude galaxy. I observed this object in a 31mm Nagler, and a 17mm and 12.5mm plossls. It remained the same distance from Antares as I moved it around the field of view, and it also remained when I put Antares just outside the field of view, so I highly doubt it's a ghost. Also, the ghosts I saw from Antares were point like, not diffuse. It is was also not M4 or the other, closer NGC globular, as they are much father away, and I did move the telescope to those targets later on just to be sure. There's nothing at that location on SkyAtlas2000, there are no objects listed in SIMBAD, and there are no currently visible comets in the area. This was observed on May 28 at around 11h UT, which was around 1am local time. Thus I doubt it could have been some satellite's fuel dump unless it was in a very high orbit (and I also didn't notice it moving relative to Antares while I was observing it). So, does anyone have a clue as to what I saw?
Cheers
Mike Connelley
Cheers
Mike Connelley
