Ghost of Cassiopeia
Object of February 8th - NGC2174/2175
Started by Inge_S, 02/08/2011 09:30AM
Posted 02/08/2011 09:30AM Opening Post
NGC2174/2175 is a much neglected open cluster/emission nebula combo. It belongs to the Orion constellation, but is actually so far to the north, that without a map giving the constellation boundaries most of us would believe it was located in Gemini or Taurus. In order to locate it I usually start with Eta Geminorum and point the scope to a position 2 - 3 degrees south and slightly west.
The open cluster is rather coarse, but not difficult to spot. Traces of nebulosity may be seen without a filter in a moderate telescope. With the O-III filter the nebula appears as an oval, pretty well-defined patch surrounding the cluster.
Posted 02/09/2011 09:22AM #1
Thanks for your encouragement on this one Inge. I had looked for it earlier this year without luck--having not read up on it as usual, I was trying to find the cluster rather than looking for a nebula, and the cluster just didn't declare itself. I still don't think the cluster stands out particularly well--seems like a thickening of the background population at best--but tonight I thought I detected a definite bright patch versus the background, this in my 10-inch f/5 (f/5.75 with paracorr) and 20 mm T5. So I popped in the OIII and the nebula stood out beautifully. (Mag 5 conditions tonight, seeing soft.) Covered maybe 20 arcminutes (so I guess I wasn't seeing all of it--listed at 40 arcmin), mag 8 or 9 star in the middle, with a lot of mottling.
A nice target for a medium aperture scope with OIII.
George Golitzin
