From a real show object, we turn to a more challenging target. IC342 is a galaxy in Camelopardalis. For an observer without GoTo or setting circles it may be difficult to locate. I usually use stars in Cassiopeia as a guide to the location of IC342. From its magnitude (about 9th) one could expect that it was easy to see even in a small telescope. However, it is large and ill-defined, and may be overlooked even when located within the field of view in a telescope of considerable aperture.
The key to successful observation of IC342 is a dark and clear sky. If conditions are good enough it can be seen with 8 inches of aperture or even less. If the sky is hazy or light pollution is a problem, just forget IC342! Together with Dmitri Kulginov I observed IC342 from La Palma (Canary islands) with my 12.5-inch. Under the superb conditions at 2400m altitude it was possible to detect the elusive spiral pattern of this face-on galaxy.
IC342 is probably a relatively near neighbour to our own galaxy. Since it is at short distance from the galactic plane, it is obscured by dust clouds in the milky way. Located in a more favourable position it would have been a much brighter and more striking object.
