The transparency, like two nights ago, wasn't great, and this time the seeing wasn't either. The session started off a little rough but improved from there.
That one wore me out a bit, so I thought I'd knock another Messier off the sketching list:
Cheers,
-- Jeff.
Arp74 11/30/2008 20:20UT; Pickering5, NELM 5.5, SQM 20.4
Not seen.
Arp145 11/30/2008 20:30UT; Pickering5, NELM 5.5, SQM 20.4
Not seen.
Arp166 11/30/2008 20:40UT; Pickering5, NELM 5.5, SQM 20.4
A small bit of a bar with two bulges along it, each containing an averted-vision semi-stellar core. The N one is slightly larger.
Arp229 11/30/2008 21:30UT; Pickering5, NELM 5.5, SQM 20.4
A whole lot going on in this field. A pair of galaxies in the center (NGC507 & 508) first present themselves -- 507 is the larger and brighter of the two, while both show semi-stellar cores. To the NNW lies another large galaxy (NGC499), this one with a well condensed core elongated ENE-WSW. To the SW lies another large galaxy (IC1685), with extremely weak condensation.
Further careful study at 235x and 335x reveals a small nearly stellar galaxy to the S of NGC507, which flirted between direct and averted vision with the seeing. Always averted vision and holdable perhaps only 35% of the time was IC1687, a tiny little smudge near the trio of stars at the center of the field. Of similar brightness, but with a hint of condensation was MCG+05-04-048, to the NE of 507/508. Even the hint of a condensation was enough to hold this one closer to 75% of the time in averted.
I was pretty chuffed about pulling in a couple of ICs and my first MCG, but I also missed several NGCs in the field (501, 503 and 510 -- I did capture 495 to the E of 499, but I mis-identified it as a star).
M33 11/30/2008 22:15UT; Pickering5, NELM 5.5, SQM 20.4
Central core semi-stellar, with a bright fan-shaped condensation extending S and E. NGC604 very prominent, with parts of two main arms direct vision. Somewhat mottled in averted. Only NGC592 is visible of the two dimmer, wider arms.
Cheers,
-- Jeff.
