Planetary nebulae seen from La Palma
Started by Inge_S, 10/02/2007 06:39AM
Posted 10/02/2007 06:39AM Opening Post
I love observing planetary nebulae. They come in so many different shapes, sizes and brightness levels, and some are quite vividly coloured. We observed many of these nebulae from La Palma, most of them old friends from the northern skies, but also a couple of new ones. Once again I only mention the highlights in this post - we observed many more planetary nebulae.
I find the three planetaries, NGC246 in Cetus, NGC1514 near the Taurus/Perseus border and NGC1501 in Camelopardalis to resemble each other. All of them have relatively bright central stars, and the nebulae have very delicate features like small condensations and dark areas. Almost like thin glass spheres floating in space. I was never able to see these details as well as under the dark and calm skies of La Palma. NGC246 is rather low as seen from Norway, and appeared surprisingly bright and nice. NGC1514 is one of my favourites. Without a filter 1514 appears as an ordinary star surrounded by some haze. The O-III filter reveals all its beauty, and it bears magnification very well. The bright and dark features of this planetary really came to their right from La Palma.
NGC40 in Cepheus appears as a smaller version of the three above.
Then we have the small, bright and strongly coloured planetaries where the "Cat's eye", NGC6543 in Draco could be considered the prototype. Of course, we observed both NGC6543 and NGC7662 in Andromeda. These nebulae, however, are both well placed for observation from the north, and are so bright that the amount of additional detail wasn't so great from the south. Both nebulae appeared extremely bright, though. The Saturn nebula, NGC7009 in Aquarius also belongs to this class. For the first time I was able to glimpse the extensions giving the popular name to this nebula.
We didn't observe the Eskimo nebula this time. However, we observed NGC1535 in Eridanus which resembles the eskimo quite a lot. It has a bright inner zone, slightly annular with a central star. Then there is a delicate outer halo, and the nebula has a nice green colour.
Of course we observed both M27 and M57. We spent quite some time with M57. We couldn't see its central star, but we were able to make out field stars in the 15.2 - 15.8 magnitude range. In order to accomplish this we had to go up to magnifications 167 - 214x. M27 was splendid floating in a rich star field.
Then we, of course, observed the oddest of the planetaires, the "Bug nebula" in Scorpius. It was a bit low in the sky a short time after evening twilight, but was still a very nice object to observe.
During this Canary Islands stay I observed two planetaries I never have seen before. NGC1360 in Fornax was a nice surprise. Without a filter it appeared as a moderately bright star surrounded by faint nebulosity. The O-III filter made it appear in its full glory - a large, oval nebula, not completely homogeneous in brightness. We called it the Rugbyball nebula - probably Americans would disagree in this name - in Europe we play soccer and don't actually know how a rugbyball looks like.
The last object I'll mention in this post is the Helix nebula. I have seen hundreds of photos of this planetary throughout the years, but I have also read observation guides stating that it is a large, very faint and ill-defined object. Therefore, when I got the Helix into the field of view I was astonished. Indeed, this is a beauty! Large and bright with much of the detail shown in photographs. The central star is easily seen along with many foreground (or background?) stars. The central hollow was obvious at first glance, and so also the outer extensions giving the nebula its popular name. With O-III the nebula appeared extremely bright, but in fact I find the unfiltered view to be more appealing. The dark centre was more obvious without the filter. It was large enough with a 24mm Panoptic, but we also studied it with higher magnification. The view of this nebula through the eyepiece was nearly worth the whole trip.
Inge S
Posted 10/04/2007 05:49AM #1
In addition the planetaries described in the parent post, I should mention NGC6572 in Ophiuchus. This object is located in the northern part of the constellation, and it isn't necessary to travel south to see it well.
With an integrated magnitude of 8.1 NGC6572 is one of the brightest planetaries in the sky. The reason why it is almost never mentioned is that it is so small that it can be confused by a star at low magnification.
I observed this nebula at a time when Dmitri had a nap. At 63x it appeared as a slightly diffuse, extremely green star. I used up to 375x on it, and at all powers it was well defined, nearly round. My personal impression is that this must be the greenest object in the sky for amateur telescopes.
Inge S
