Jay Messeroff
Lunar & Solar Transits
Saturday Night in a Home Dome, 2003/11/14 UT
Started by Dave Mitsky, 11/25/2004 05:51AM
Posted 11/25/2004 05:51AM | Edited 11/28/2004 03:50PM Opening Post
This report falls into the better late than never category I suppose.
On Saturday, November 13/14, I spent some time observing at the eyepiece of a 20" f/10 classical Cassegrain located at a friend's observatory. It was a fairly good night in terms of seeing and transparency. The first object we viewed was Comet Tucker Q1 . It appeared as a small, rather unimpressive fuzzball at 203x (25mm University Optics MK-70).
We then had a look at the bright spiral galaxy NGC 7331 in Pegasus. Using 203x and 302x (16.8mm Orion MegaVista) we studied the field and eventually positively identified four of its faint companion galaxies, namely NGC 7335, NGC 7336, NGC 7337, and NGC 7340. These galaxies range in brightness from mid-thirteenth magnitude to mid-fourteenth magnitude. NGC 7336 was the most difficult of the bunch to detect.
After slewing the big scope slightly southward, I noticed that NGC 7320, the brightest member of Stephan's Quintet, was fairly easy to discern. We didn't spend much time on the remaining members.
The next celestial target was another comet, Comet Maccholz Q2, at 127 (40mm Orion UltraScan), 159 (32mm Edmund Scientific Erfle), and 203x. I noted a wedge-shaped coma and a short tail that pointed to the northwest.
The planetary nebula NGC 1535 in Eridanus was a fine target using the 25mm with Orion UltraBlock and Lumicon O-III filters. At 127x an unfiltered NGC 1535 displayed a pleasing blue hue and a prominent central star.
The face-on spiral galaxy NGC 1232 (203x), also located in Eridanus, was fairly large and rather faint.
I showed my friend the fine binary star 32 Eridani, which is somewhat reminiscent of Albireo (Beta Cygni) as far as the colors of its components are concerned.
My friend had to get going so after taking a peek at the supernova remnant M1 we closed the Home Dome and went home.
Dave Mitsky
Posted 11/27/2004 09:38PM #1
I read your post and went to my logbook for 11/13-14. I also was observing at a friend's backyard about 30 mi west of Clarksburg, WV. Temperature that night was in the upper twenty's and the sky was- M 33 naked eye. We were using his Meade 10" SCT and I set up a homemade 18" dob by 1700. We got back from our club meeting by 2000 and got things rolling.
Ron was working with charts and optical finders on the Herschel 400 . He had a slow start, but picked up about 8 by evenings end.
With the 18 f/5 ,I went back to the Aries trio of NGC 1024,1029 and finally got 1028- truly a faint fuzzy-using a 14 mm Meade UWA(160x).
Over in Cetus to M77 (very well defined core and halo)to help locate NGC 1055-this one would be a beauty if not in the glare of 2, 7th mag stars-and then to NGC 1072 nearby.
By the way does the light from an electric space heater coincide with red light for maintaining night vision?
We both had a great evening and enjoyed one of the best skies we have had this year.
We all have so much to give thanks for each day.
John Dennis
