Some exotic DSOs observed 8th of October
Started by Inge_S, 10/11/2004 06:25AM
Posted 10/11/2004 06:25AM | Edited 10/11/2004 06:26AM Opening Post
I've already posted a list of galaxies observed 8th of October. However, I observed several other DSOs that night, some of which are rarely mentioned under this forum.
In the southern part of Perseus I spotted two diffuse nebulae, NGC1333 and NGC1579. The first one was the less visually interesting. It was just a large, ill-defined patch of light with one star involved. The background was unusually poor due to obscuring clouds. I almost had the impression of viewing from a highly light polluted area. NGC1579 appeared as a double nebula. Not a show object, but worth the search.
I also found the open cluster, NGC1245 in Perseus. This was one of the evening's greatest surprises. It is a rich cluster, reminding me of NGC6939 in Cepheus, but with a brighter star at the edge. Recommended!
After the mandatory viewing of the North-America nebula and the Veil, I checked the region near Gamma Cygni. Embedded in the rich star field I noticed a large, faint patch of nebulosity, which I later identified as IC1318b. It is listed as an emission nebula, but the O-III rather killed the nebula than enhancing it.
I re-observed NGC7331 in Pegasus, and used more magnification than last time. 120x brings out more detail than 63x, but I was still only able to see one of the satelite galaxies, NGC7335. Using the same magnification on Stephans quintet revealed three separated nebulous patches, presumably NGC7318/7319/7320.
Finally I'd like to mention NGC7479, south of Alpha Pegasi. I remember when observing it with the 8-inch a year ago I found it faint and uninteresting. In the 12.5-inch, however, it is a much more striking object, and the spiral structure can be made out.
Inge Skauvik
Haavik, Norway
