I haven't posted here in ages, but I thought I'd share a couple of recent observing reports.
Over the summer I acquired both Alvin Huey's and Kanipe & Webb's Arp Peculiar Galaxies books, but I'm a bit embarrassed to say that I hadn't used either in anger yet. I finally got a chance to correct that on Thurs night.
This was a short session due to having spent all day cooking. I was also using a plan that had been prepared for October (which lay unused due to cloudcover) -- so I just picked a couple of the later (RA-wise) ones which were still fairly well-placed.
Conditions were mixed: better than average seeing for my site, but worse than average transparency.
-- Jeff.
Note: Arp331 is probably an example of where I should have gone out with a chart -- I expect with a bit of prompting and knowing where to look I could have found NGC387 and possibly even 388. But I still have a preference for taking my first observation of a target "blind" (so that I'm unbiased in recording what I see).Arp331 11/27/2008 23:30UT; Pickering 8, NELM 5, SQM 20.4
5 direct-vision plus 1 averted-vision galaxies. NGC383 the brightest, but 380/379 readily visible to the NNE and 384/385 somewhat less so to the S. NGC386 could only be teased out with averted vision; holdable perhaps 35% of the time but easily re-acquired.
NGC380 has stellar core; NGC379 slightly larger but with a less condensed core. NGC383 has largest core, elongated somewhat NNE-SSW. NGC384 and 385 show very weak semi-stellar cores under averted vision.
Arp158 11/27/2008 23:55UT; Pickering 8, NELM 5, SQM 20.4
Small elongated streak, but without the swelling so typical of edge-on spirals or lenticular galaxies. Two brighter knots, both semi-stellar in appearance; one at E end and second about 2/3 of the way to the W end, connected by a brighter bar. Dimmer knot between the other two not seen, nor was the exceedingly faint extension to the ESE.
-- Jeff.
