Some thoughts after trip to La Palma
Started by Inge_S, 09/18/2007 02:03PM
Posted 09/18/2007 02:03PM Opening Post
The summit of Roque de los Muchachos has been chosen as the site for several professional observatories because of stable weather conditions, generally good seeing and a darker sky than anywhere on the European mainland.
Our second visit to this site was a unique experience. Here we had the opportunity to really push both our equipment and observation skills to the limit.
Dmitri was able to view stars in the magnitude range 15.7 - 15.8 near the Ring Nebula through the 12.5-inch Portaball(While I had to be satisfied with 15.2 - 15.3). The corresponding naked eye limiting magnitude should be somewhere around 7. The zodiacal light was quite bright in the morning, and none of us had problems seeing the Counterglow or Gegenshein in the position opposite to the sun.
I gave Dmitri the task to make a drawing with the positions of as many of the galaxies in the Fornax group he could see. While I could make out 11 he correctly noted down the positions of 15, and even their orientations (except one) were correct. A few of these galaxies are fairly bright, and for NGC1365 the spiral pattern is easy to see with direct vision. However, quite a few of Dmitri's 15 are very faint, and can easily be taken as faint stars. I'm impressed.
Seeing was good already a short time after sunset, and in most cases excellent before dawn. Beta Delphini which is getting quite close now was notched in Dmitri's C8, and a clean split was obtained with the Portaball and a 3.5mm Nagler.
Eckart Fuchs brought along a super-portable 8-inch f/4 Newtonian. With growing experience this telescope also performed really well. With a 24mm Panoptic it gave beautiful widefield views (more than 2 degrees FOV), but it also gave images with good resolution and contrast of Jupiter. Not bad for a scope that can be collapsed to a package small enough to be carried as hand luggage with the airlines.
I plan to make some posts about some of the interesting objects we observed during our week down there.
My main conclusion from our trip is the following: In order to get the most out of visual observation the following factors must be optimal:
Sky darkness
Atmospheric transparency
Seeing
Equipment
Eyesight of observer(s)
Observational comfort
During our present trip all these factors were in place. We have already started discussing where and when to go for our next astro trip.
Inge S
Posted 09/18/2007 02:45PM #1
I thought I'd be adding some comments along with Inge's posts. The trip was absolutely phenomenal. Here are some statistics of my own observations:
I made about 240 observations, including 90 with my own C8 (mounted alt-azimutally), 180 with Inge's 12.5" Portaball and around 20 with Eckart's 8" Newtonian. All three instruments performed as good as one could expect from them. My only failure was splitting Sirius, we could not see the companion however hard we tried.
We observed many galaxies which often came in groups (Glx in the attached pie chart; Gcl stands for galaxy clusters), globular clusters (GC) mainly in Scorpius/Sagittarius which were visible after the sunset), and bright nebulae (DN). Open clusters (OC) received less attention. Inge found many fine planetary nebulae (PN), and I tried to find some dark nebulae (dkN) for the first time.
Dmitri
kulginov's attachment for post 116926
