Starhopping to NGC 4565
Started by kcolter, 12/20/2003 06:18PM
Posted 12/20/2003 06:18PM Opening Post
Any of you veterans have any special tricks for star hopping to NGC 4565? Sometimes I find it quickly and sometimes I wander all over the open cluster looking for it. Early this AM the seeing and transparency in the Midwest were superb but my starhopping skills were not. I spent an embarassing amount of time looking for 4565 after the battery in my Sky Commander died. Thanks for any suggestions.
Posted 12/20/2003 08:23PM #1
Kim,
Do you have a good star chart, like SkyAtlas 2000 or Uranometria? The position of 4565 is depicted on the Sky Atlas. Also, do you have a telrad?
I presume you're referring to the wedge-shaped group of stars 10 degrees SW of Cor Caroli. I don't know if it's a cluster, but it's a nice, tight grouping of stars you can use to find several interesting galaxies in the area. Starting from the star located at the SE corner or apex of the wedge, visualize a line extending E-W from that star through the star in the SW corner of the wedge. Note the interval between the apex star and the SW corner star. Now extend that line to the east from the apex star, going the same distance as the interval. NGC4565 is located there. If you sweep east from the apex star, look for elliptical galaxy NGC4494 a bit less than halfway along the line to 4565.
Happy hunting!
Howard
