At last I had the chance to observe all the great nebulae in the direction of Sagittarius (M8, M16, M17 and M20). Among these only M16 and M17 can be observed from home, and only for a very limited time of the year. From La Palma there was time to really enjoy the objects and play around with magnification and filters.
All the four nebulae are easily visible without filters, M17 being the most striking one. With O-III (which is the most versatile of the narrowband filters for these nebulae from my experience) M8 gains so much that I would put it as Number One. M8 is a beauty unfiltered, but with O-III it is gorgeous. With the 13mm Nagler eyepiece (115x) it shows a tremendous amount of bright and dark detail, and appears like a gigantic vortex in space.
The visible extent of M17 also increases a lot when using the filter, and lots of fine structure becomes visible. Neither M17 nor M8 are much inferior to the great Orion nebula when observed through a filter.
M16 is very nice both without and with a filter. The filter is necessary to make out the dark "fingers", and it is not a bad idea to use some magnification (115x rather than 63x) to study these details.
After trying both O-III and H-beta on M20, my conclusion was that it looked best without a filter. Both filters enhance the nebula a little, but they are not needed to see the dark lanes clearly. And the beautiful quadruple in the centre of the "trifid" is definitely best unfiltered.
Several other diffuse nebulae were also observed from La Palma. I'll comment on them on a later occasion.
Inge S
Inge S
