The Horsehead Nebula through an 8" Aperture
Started by Dave Mitsky, 02/18/2009 08:03PM
Posted 02/18/2009 08:03PM Opening Post
On Monday night I was at one of the better nearby dark sites, if a location at a distance of 42 miles can be considered nearby, along with four fellow observers. Two drove to the summit of the mountain, while three of us opted for a lower site that is far more sheltered from the wind, which was quite gusty at times. The transparency was good, particularly so early in the session, and the seeing was variable.
One of my goals was to give a certain celebrated deep-sky object another go with my Zambuto-powered 8" f/6 Starsplitter Tube Dob. Not long after I arrived I trained my scope in the requisite direction. Orion was just past the meridian at the time. I spent at least 15 minutes scanning the area using a borrowed H-beta filter and I'm reasonably certain that I did indeed detect Barnard 33, the Horsehead Nebula, through my 8" scope. Previously, the smallest aperture that I've successfully observed this famous dark nebula with was an old 13.1" Coulter Dob at Cherry Springs State Park, a location considerably darker than the Peters Mountain site. In the past, I've been completely unsuccessful in logging B33 with my 101mm Tele Vue refractor.
NGC 2024, the Flame Nebula, was straightforward and IC 434, the emission nebula that B33 juts into, was fairly easy to see but I couldn't make out the Horsehead until I darkened the field by completely surrounding the eyepiece with my hood and gloves. I noted a very elusive notch exactly where B33 should be four or five times for a span of several seconds.
Dave Mitsky
Posted 02/18/2009 08:17PM #1
Dave: A nice report and congratulations... A question or two if you would:
The Horsehead is one of my goals for this spring. Over the Christmas vacation I spent time familiarizing myself with the region and detecting IC-434. I was using my 12.5 inch F/4.06 with an Orion H-beta filter. There were moments when I thought I had perceived the Horsehead but there never was a definitive moment where I could say "Eureka, Eureka."
I am hoping to get out Saturday night with my 16 inch F/4.42 and would like any advice you have for me, particularly in my choice of eyepieces. The filter is a 1.25 inch so that restricts my choices of widefield designs, I have a 22mm pan plus 16mm and 12 mm Naglers... I normally use these with a Paracorr... (=F/5.1) If a larger exit pupil were desirable, I could use a 32mm Plossl...
Good job...
Posted 02/20/2009 10:13PM #2
Hi Dave,
Reading your comment on seeing the Flame Nebula and IC434 prompts me to ask: What's the minimum aperture required for seeing them? Thanks.
Mark Costello
Matthews, NC
Mark Costello
Matthews, NC, USA
"I hear you're mechanically inclined. Did you ever do anything with perpetual motion?"
"Yeah, I nearly had it a couple of times."
Posted 03/09/2009 02:48AM #3
Hi Dave,
Sometimes you can do the impossible, or near impossible. I saw the central star in the Ring Nebula with an 8" reflector scope (with new mirror). It blinked at me a few times, quite definitely, but that was all. Never been able to repeat the event.
I have split the Double-Double in Lyra at 62X with a 4" Mak-Newt, but the best I have done with my 8" Schmidt-Newt is 80X, and 75X with a 6" Mak-Cass. The exit pupils are evidently too big in larger scopes to get good splits at low powers.
I saw a dark stealth aircraft at high altitude on a full moon night as the moonlight reflected off of it and silhouetted it against the sky. I have seen bats flying at altitudes I never would have guessed they would fly at. Are there that many bugs a mile above the earth to make it worth their time and effort???
I have seen stranger stuff than that as well, but I'll keep it to myself for now. :-)
Phil
