The M82 class of irregular galaxies
Started by Inge_S, 12/07/2007 12:48PM
Posted 12/07/2007 12:48PM | Edited 12/07/2007 12:50PM Opening Post
The first time I saw M82 through the telescope (one of my greatest astronomical memories) I thought it was a typical example of an edge-on spiral. Later I have realised that this actually is a peculiar galaxy with absorbing dust bands crisscrossing its surface in a more random way. These bands can be seen visually in a small or moderately sized amateur telescope. A good 8-inch scope with a magnification of 150 - 200x gives a good view if the sky is dark and clear.
M82 is not the only example of this galaxy class. I recommend a look at the following objects.
NGC3556 (in the same field as the Owl nebula). This galaxy is smaller and fainter than M82, but the general appearance is quite similar. The dust bands are obvious in a 12.5-inch scope.
NGC55 in Sculptor is the best of all galaxies of this class. It puts M82 to shame, being brighter and considerably larger. The drawback is its location far to the south. At La Palma I used the northern stars of Phoenix to help me locate this awesome galaxy.
Then there are two galaxies where I have to admit that I'm a bit uncertain about the classification.
NGC253 in Sculptor also has some resemblance with the M82 class. It could easily win a contest as the best galaxy in the sky viewed through a telescope (M31 being too large). The galaxy definitely contains an irregular pattern of obscuring clouds, but it is far more regular in shape than both M82 and NGC55.
NGC4631 near the Coma Berenices /Canes Venatici border also appears to contain irregularly arranged dust clouds when viewed through a telescope. I even believe I have seen photos revealing such clouds.
Anyhow, all the galaxies listed hare are very good objects for telescopes in the amateur range. Any comments and observing reports are welcome.
Inge S
