The Sculptor galaxies
Started by Inge_S, 09/19/2007 11:58AM
Posted 09/19/2007 11:58AM Opening Post
Sculptor contains some of the most beautiful galaxies in the sky. Unfortunately navigation in this region in the sky is rather difficult (not a problem for high-tech astronomers, though). We observed the most famous of the galaxies in this region from La Palma. The highlights were NGC253 and NGC55, but also NGC300, NGC134 and NGC247 (In Cetus) are worth mentioning. This post contains my impressions - but I'm sure that Dmitri can add interesting information.
NGC253 is an extremely beautiful object. Its outline is a nearly perfect ellipse, and the surface brightness is relatively high, but varies a lot over the area. This is a huge galaxy which extends outside the field of view even with moderate magnification. Obscuring nebulae are obvious at first glance. With higher power high brightness patches appear - obviously starburst regions or emission nebulae. Hints of spiral structure can be made out. Particularly the arm along the south-western edge is easy to see. For me a dream came true as I allowed the galaxy to drift across the field of view at 115x magnification. No photo can justify the view seen directly through the eyepiece under such conditions.
The second brightest and largest Sculptor galaxy is NGC55. This is also a galaxy with a huge apparent size, and although it is a bit fainter than 253 it is still an impressive object. It resembles NGC253, but is even more elongated and a bit irregular. The brighter parts are asymmetrically placed - the north-western part being the brightest. Also NGC55 contains obscuring patches and lanes. A superb galaxy.
NGC300 is a moderately large spiral galaxy with some foreground stars making observation of its details a bit difficult. It appears as a slightly smaller and fainter edition of NGC2403 in Camelopardalis.
NGC134 is another fine object. It is a tilted spiral. At first glance its light appears to fall off abruptly along one of its edges. With more attention is becomes obvious that the reason for this is an absorbing lane.
Finally, NGC247 in Cetus should be mentioned. This galaxy can possibly be seen even from Norway, but it is much better from a location further south. It appears as an elongated ellipse oriented almost north - south with a star at one of the ends. A pretty large object with a rather low surface brightness. An interesting galaxy with an appearance through the eyepiece that can't be confused with any other galaxy in the sky.
Inge S
Posted 09/19/2007 02:28PM #1
NGC 253 is one of the absolute highlights of our trip. I had seen it in 80mm achromat and 15x70 binocular before, and it was impressive in both because it is large and has considerable surface brightness. But the extremely dark and steady skies of La Palma together with good aperture of 20-30cm make it a totally different story - the best photographs can only hint of its glory.
We used powers from 60x to 215x to study very rich light and dark detail of this galaxy, and it was excellent at each magnification. In 7mm Nagler many dark regions can be seen by direct vision, including one long stripe that seems to mark a spiral arm. The very central part is elongated and bright, and I suspected a bright core there. At the same time, a quick look with averted vision would instantly reveal the full extent of the galaxy even at high power; it is longer than the FOV of 9mm Nagler. Both ends are very mottled, and there are many foreground stars of different brightness that make the view even more appealing.
Dmitri
Posted 09/19/2007 05:54PM #2
I recently (9-14-07) observed and then photographed NGC253, a great galaxy. Wonderful object and a fine example of the type. Here is the image I took.
fblue's attachment for post 116953
Posted 09/24/2007 12:50AM #3
Inge, did you notice a remarkable asterism just off the southwestern tip of 134? It is a square of roughly equal mag 10 stars, about 5 minutes on a side, with a little mag 12 or so star smack in the middle. An arresting sight next to the fine galaxy.
Regarding 253, I have often had the same emotional response at the eyepiece from my dark site at hyampom (http://www.cleardarksky.com/c/HympmCAkey.html?1)
--with a 13" or my 16", the mottling, dark lanes, and eery glow find expressions in my journals such as "mind-blowingly beautiful" (9/03/05) "fabulous!" (9/20/04) and "incredible" (10/24/03)--a photo (no offense floyd--that's a nice photo!) cannot touch the experience at the eyepiece..so often I come away from these encounters refreshed in spirit, and thankful.
--george
George Golitzin
