The Veil at Last! Sort of...
Started by darylc, 09/10/2004 12:04PM
Posted 09/10/2004 12:04PM Opening Post
In my never ending attempts to catch sight of the Veil I believe I actually saw a piece of it last night.
I was scanning the for the Veil, which was directly at zenith, so I figured I might have a chance given the Veil's location and seeing was about an 8 out of 10 last night.
I was using my 15x70 binoculars and I spotted what appeared to me as a slightly circular patch that looked a lot like a distant OC. Upon checking the star maps, there was no similar OC in the area, but the top of the Veil was exactly in that position.
While it hardly qualifies as seeing the Veil, I feel confident that I have at least seen a piece of it, finally.
Daryl
Posted 09/10/2004 04:36PM #1
You know, I've seen the Veil before, but just last night I saw it in binoculars for the first time myself. And, I sh** you not, with 8x42s. I almost couldn't believe it, so I pointed my finder precisely at the same star field (couldn't see the Veil in my 50mm finder, though), looked in the eyepiece, and there it was, arcing through the eyepiece.
It does indeed look like a distant, oddly shaped, OC in binos. Part of the issue in seeing the Veil for the first time is knowing what to look for. I only found it in my scope after first being shown it in someone else's scope - once I knew more or less what to look for, it was suprisingly easy. As long as the skies are dark and clear, at least. I never expected to see it in 42mm binos, though. (although I have seen it in my 50mm finder once while holding a nebula filter in front of the eyepiece).
Isn't it strange how something can be so difficult to find sometimes, but under the right conditions you can see it with hand-held binoculars?
Posted 09/11/2004 01:15AM | Edited 09/12/2004 02:46AM #2
Hi Daryl,
Did it look a little like this ... ?
http://www.astromart.com/forums/viewpost.asp?forum_post_id=221652&poll_id=&news_id=&page=
I was surprised how large it was, but very faint.
David Simons
David Simons
