Triangulum Galaxy (M33)
Started by vsvenson, 11/10/2004 02:19AM
Posted 11/10/2004 02:19AM Opening Post
I decided to try and find M33 tonight, and after some careful looking and star hopping, I was able to find it.
It felt like a real achievement when I did find it, but also a little dissapointing. I guess I was hoping for a smaller version of Andromeda, but really it looked like a smudge on the eye piece! In fact, I think I skimmed over it a few times before realizing what it was.
So, I was curious what success others have had...
I'm using an 8" SCT at 50x magnification.
Posted 11/10/2004 03:35AM #1
On a particularly transparent night, from a dark location, M33 can be quite rewarding. But the slightest bit of brightness or haze transforms it back to a dim smudge. It'll probably look better in binoculars than your SCT.
M101 is similar, even more so.
Around this time of year, check out NGC253, which is closer to a mini-Andromeda than M33. It's pretty far south, but as long as you don't live too far north NGC253 should be a more-rewarding galaxy in your SCT than M33.
Posted 11/10/2004 03:50AM #2
I have a 10"dob and mag 4 skies overhead - M33 wasn't hard to find, just hard to recognize - looked right through it many times before learning to see it, found that moving the scope a wee bit helped a lot and I could discern some shape to the glow.
UMaj is moving into favorable viewing position for me now, M51 and 81/82 are favorite targets and show well even through my urban sky, whereas M101 is just rumor...
Jim Cantrell
Posted 11/10/2004 08:26AM #3
Under dark conditions and transparent skies hints of the spiral structure of M33 can be med out with an 8-inch scope. Increasing the aperture form 8 to 12.5 inches makes a great difference. Several of the galaxy's emission regions become visible, and the spiral structure becomes much more obvious.
I have observed M33 with different magnifications, and it seems to me that with a 12.5-inch scope 100 - 120x gives the best views.
Most observers agree that M33 is more elusive than would be expected from its integrated magnitude. I recommend novice galaxy observers to try M81 and M82. They are both well defined, and have a high surface brightness. And they are so close to each other that they can be viewed together in a low power field.
Inge S
Posted 11/10/2004 10:28PM #4
I will echo what others have said about the clear dark skies. In my 8" reflector I have seen some nice views of M33. On those nights M31 was very very nice. In hindsight I would say if you pick up M110 pretty good when viewing M31, then M33 will likely give you a nice view.
I viewed mainly between 40x and 80x.
Ed
Posted 11/11/2004 07:42PM #5
It's better in binoculars, so is M102, so is M31 for that matter.
Daryl
Posted 11/13/2004 03:32AM | Edited 11/17/2004 12:44PM #6
There's an excellent article on M33 and the various HII regions and globular clusters that can be seen with amateur instruments in the December 2004 Sky & Telescope. I've had some great views of M33 through large apertures (up to 32") and have seen a number of the extragalactic objects mentioned.
Dave Mitsky
