james carter
North American Nebula NGC7000
Was this the North America Nebula?
Started by Doug Smiley, 11/29/2002 09:29PM
Posted 11/29/2002 09:29PM Opening Post
I had the opportunity to observe under excellent skies recently using a 120mm F5 refractor with a 35mm Panoptic (17X) and UHC filter. Just to the east of Deneb was a huge field of nebulosity glowing with an icy subdued incandescence. It was absolutely one of the most gorgeous sights I have seen in three years of stargazing. I am thinking that it had to be the N.A. nebula,(which I had never before seen) but what I saw was larger even than the 3.6 degree true field of the Panoptic. Isn't the N.A. nebula only 1.5 degrees across?
Posted 11/30/2002 02:13AM #1
It certianly sounds like the N.A. nebula, which is certainly over 3 degrees across. The veil is just about 1.5 degrees across (also in Cygnus). I find both to be fairly awe inspiring, and worth the cost of a 2 inch UHC filter.
Posted 11/30/2002 09:21PM #2
Doug,
It certainly sounds like you did see NGC 7000 (the North America Nebula),which lies about 3 degrees away from Denber and is larger than the figure you mentioned. A roughly V-shaped asterism leads from Deneb and cuts through the East Coast of NGC 7000 and IC 5067-70 (the Pelican Nebula). Under exceptional skies the Pelican Nebula is also visible through rich-field telescopes.
See http://www.astro.univie.ac.at/~koprolin/Photo/Neb/Northamerican_Pelican_APO.html
Dave Mitsky
