Wizard Nebula
Blue Color on Mars Northern Limb
Started by Jafo55, 09/19/2003 12:45AM
Posted 09/19/2003 12:45AM Opening Post
Doug Scobel mentions that he is seeing some blue color around the northern limb of Mars. I too have seen the same light-blue edging on the northern limb. In my refractor I dismissed it as chromatic abberration in my doublet .... in my 12.5" f/5.6 reflector its a lot harder to do. I use 4.8mm, 7mm, and 9mm Naglers which should be very well color corrected (or I'll be calling Al tomorrow), in my scopes for Mars observing. If the color is due to atmosphere, the color should come and go with changes in the seeing, I have not noticed this happening. I personally think Doug is seeing something in the atmosphere of Mars.
I used a number of different color filters while observing Mars and the blue color is even more evident with the #11 yellow and #15 light-orange. I actually added it to my latest drawing, which is posted on this site, however the scanner did not do a very good job of picking this up.
Doug, I'll show you the drawing at the next meeting.
Clear Skies & Dark Nights
Mark S Deprest
Posted 09/19/2003 01:10AM #1
I have also seen a blue fringe around the
northern limb, accompanied by reddish fringe
around the southern limb, in my Mak-Cass.
I thought it was atmospheric dispersion.
Mars is only about 24 degrees above my horizon
at best.
Posted 09/19/2003 01:22PM #2
Indeed I often see a bluish haze on the northern limb, but still I suspect that what I'm really seeing is artificial. My reasons for thinking so is because when it is most noticeable, I also see a reddish tinge along the southern limb. It also gets more and less noticeable when I move Mars around in the field of view. And, I remember it being quite symmetrical. This suggests to me that it's either a small amount of chromatic aberration in the eyepiece, or maybe some atmospheric dispersion (Mars barely gets up to 30 degrees altitude from my location), or maybe some of both. If it were really a Martian feature, then I would simply see the bluish fringe without the red. Plus, its very narrow, not 1/7 of the Martian disk as Sol mentioned.
I have #25 red, #58 green, and #80A (light) blue filters, but not a #38 (dark) blue. Next time I'm observing I'll give it a closer look.
Doug Scobel
