Class Night at the Naylor Observatory, 2003/5/14
Started by Dave Mitsky, 05/15/2003 03:44PM
Posted 05/15/2003 03:44PM Opening Post
I drove to the ASH Naylor Observatory (click on
Naylor Observatory at http://www.astrohbg.org ) last
night to help out with the spring introductory astronomy class. The
class had already done a bit of solar observing with our old
orange-tube 8" f/10 Celestron C8 before I arrived. Although the sun
was getting fairly low in the sky I took a quick look and saw three
smallish sunspots.
I sat in on the class until the sky began to darken. I was aware
that a rather rare shadow transit by Callisto was underway and went
out to see it through our 12.5" f/6.5 Cave Astrola. The shadow was
clearly evident through a 15mm Edmund Scientific RKE (138x).
Callisto and Io were closing in on a mutual occultation (see
http://skyandtelescope.com/observing/objects/planets/article_771_3.asp
for further information) that eventually occurred at 12:11 a.m. EDT
(4:11 UT 5/15).
As the students started to filter outside I trained the C8 on Jupiter
using a 13mm Tele Vue Ploessl (156x) and then opened the French Dome.
The transit was displayed quite nicely at 202x through our 17" f/15
classical Cassegrain and a 32mm University Optics Koenig-II. After
the students all had had a turn I increased the magnification to 259x
(25mm U.O. MK-70), but the view was a bit soft given the seeing. A
28mm RKE (216x) provided a great view a bit later.
We began looking at the 13-day old moon and other objects with the
12.5" Cave, the C8, and our 10" f/7 Cave Astrola. I swung the 12.5"
to Saturn and then the 17". A few double stars (Mizar, Castor, and
Algieba) were sprinkled in as well.
Callisto's shadow reached the CM around 9:00 p.m. EDT (2:00 UT 5/15).
Bob Young, the class instructor and the club's resident lunar expert, and I
spent a few minutes on the moon (not literally mind
you) as some clouds began scudding through. Reiner Gamma
( http://web.tiscali.it/no-redirect-tiscali/themoon/reinergamma.htm )
was a standout feature.
So on the first semi-clear night in some time an enjoyable
evening of observing occurred despite the bright moonlight and occasional clouds.
Dave Mitsky
Harrisburg, PA
