Philip Imbrogno
Elephant Trunk Nebula
Coping with the shadow of the secondary?
Started by auriga, 02/15/2007 02:02AM
Posted 02/15/2007 02:02AM Opening Post
Hello, everyone,
The shadow of the diagonal bothers me greatly when I observe the moon with my reflectors (11 inch fr4.55, 6 inch f5, and Starblast 4.5 inch f4r). I often have to look in the eyepiece from the side to avoid it somewhat.
How do you cope with it? More aperture to get a bigger exit pupil at the same magnification? (This will help with floaters, I am told)
Or more magnification with the same aperture?
Bill Meyers
Posted 02/17/2007 04:02AM #1
Bill,
This problem goes away by using a 12.5mm EP instead of the 25mm on my little reflector. This gives twice the magnification of course and a smaller exit pupil. I only see the shadow with very bright objects like the moon or during the day.
Try a little higher magnification until the shadow goes away.
Regards,
Rick
8" Zhumell Dob
90mm f11 achro refractor
Posted 02/17/2007 08:40PM #2
Bill Meyers
Bill:
I only notice the secondary shadow when using large exit pupils. If I am operating at F4.7 with a 25% Central obstruction then the CO has an effective focal ratio of F/18.8
Pop in a 32mm eyepiece and hole in the center, the pupil of the Central obstruction is 32mm/18.8mm = 1.7mm.
Since the moon is bright enough to cause the eye to constrict to near daylight proportions, ie 2mm, this 1.7mm exit pupil is very noticeable unless I am off the side.
But add a bit of magnification and that problem, for me, disappears.
The moon at 40X can be very pretty but for real observation, much higher powers are desireable so this seems to be a non-issue.
jon
