Philip Imbrogno
Elephant Trunk Nebula
Disks of Jupiters moons
Started by wisemanrs, 08/15/2009 02:19PM
Posted 08/15/2009 02:19PM Opening Post
All,
Is it possible (or at all probable) to see the disks of Jupiter's moons in an 8" f6 Newtonian at 320x? I thought that was what I wa seeing last night at midnight local time. How many arc seconds wide are the moons' disks?
Checking Starry Night to identify the moons, this is what I observed: Leading was Callisto, second largest disk, dull color, second was Ganymede, easily the largest disk, still a dullish surface. Following the planet were Io and Europa, fairly close together, with smaller much brighter disks. There was a dim star between and a bit below Callisto and Ganymede.
The limb of Jupiter was very sharp, and many details were clear on its disk. I checked some nearby stars about the same brightness, they appeared much different, intense and twinkling with diffraction rings. Zeta Aquarii at 2 arc seconds was easy even at 80x. Seeing was obviously exceptional.
Rick Wiseman
8" Zhumell Dob
90mm f11 achro refractor
Posted 08/15/2009 03:01PM #1
Rick-My old RV-6 could show the moons as discs easily. It wasn't too hard to identify the moons based on their size & brightness.
