Io Does Its Thing, 2003/3/19 UT
Started by Dave Mitsky, 03/20/2003 06:15AM
Posted 03/20/2003 06:15AM Opening Post
After the ASH advanced astronomy class had ended I watched Io's shadow transit using the 17" f/15 classical Cassegrain at the Astronomical Society of Harrisburg's Naylor Observatory (see http://www.astrohbg.org/gallery/index.php?show=./visit/3b_17_inch.jpg&offset=0) on Tuesday night, March 18th.
The transparency varied from bad (i.e., mostly cloudy) to mediocre but the seeing was excellent. In fact, I was quite surprised at just how good it was. The shadow of Io was a sharply defined black spot that crept slowly along Jupiter's equator. I was able to push the magnification to as high as 404x (16mm Brandon) but 249x (26mm Tele Vue Ploessl) provided the best overall view. Other magnifications used were 162 (40mm University Optics MK-70), 202 (32mm U.O. Koenig-II), 216 (28mm Edmund Scientific RKE), 259 (25mm MK-70), and 381x (17mm Pro-Optic Ploessl). The size and brightness differences of the Galilean satellites were quite apparent.
The shadow crossed the CM at about 10:40 p.m. EST (3:40 UT). About 3 minutes prior to the end of Io's transit (4:01 UT) I could make out the shape of Io as it neared Jupiter's preceding limb. By 4:03 UT Io had pulled far enough away from Jupiter that I could see a gap. As the gap widened the fact that Io was casting its shadow on the cloud tops of its parent planet grew increasingly evident.
Dave Mitsky
Harrisburg, PA
Posted 03/20/2003 05:57PM #1
Dave,
A nice view of the shadow of Io and later the satellite itself. I hope that you enjoy many more such observations in the future.
Carlos
Posted 03/21/2003 11:53AM #2
I also followed an Io transit a couple of weeks ago with my 8-inch Portaball. Both seeing and transparency were excellent, only occasionally the images trembled slightly. I didn't know which moon was transiting, but just accidentally turned my scope towards Jupiter just before second contact. Looking for a bright satelite disc towards Jupiter's surface I failed to see the moon itself in the beginning. However after a while I saw the small, dark spot moving along the equator, and then I realised that it was Io. The last minutes before the end of the transit Io appeared as a bright spot (not dark any more) against the darker limb of the planet. The shadow, of course, appeared as a punched hole in the planet all the time. The contrast of the features of Jupiter's atomsphere was excellent this evening. During the last part of the transit the GRS appeared, and a lot of smaller features were visible in Jupiter's belts. I used a 5mm ortho for the observation, giving 240x power.
