Jupiter Observation (May 21, 2006)
Started by Martian, 05/23/2006 07:04AM
Posted 05/23/2006 07:04AM Opening Post
I made an observation of Jupiter on May 21, 2006 at 04:40 U.T. under steady seeing conditions (7-8/10). The North Equatorial Belt (NEB) and South Equatorial Belt (SEB) exhibited interesting and complex detail. I welcome any comments that you may have on my observation.
Date (U.T.): May 21, 2006
Time (U.T.): 04:40
L1 032.6, L2 221.8, L3 004.0
Diameter (arc-seconds): 44.3
Instrument: 9-inch (23-cm) F/13.5 Maksutov-Cassegrain
Magnification: 272x
Filters: None (IL)
Seeing (1-10): 7-8, Antoniadi (I-V): II
Transparency (1-6): 4-5
Notes:
South Polar Region (SPR): Appears dark to dull (3-5/10) and mottled. It's northern border appears to deviate southwards preceding the CM and a South Tropical Zone (STrZ) band.
South Tropical Zone (STrZ): Appears bright (7/10) and contains a dark (3/10) wedge-shaped band over it's preceding-southern portion.
South Equatorial Belt (SEB): Appears bisected by a confluent group of bright (7/10) ovals with dark to dusky (3-4/10) northern and southern halves.
Equatorial Zone (EZ): Appears dull to bright (5-7/10). It's preceding half (especially southern portion) appears dull to shaded (5-6/10). Dusky to dull (4-5/10) projections from NEB-S festoons are noted over it's mid-portion.
North Equatorial Belt (NEB): Appears dark to dull (3-5/10) with bright (7/10) ovals and dark to dusky (3-4/10) condensations within it. A very bright (8/10) oval is noted along the northern border following the CM. Dark (3/10) blue festoons are noted along the southern border (NEB-S).
North Tropical Zone (NTrZ): Appears bright (7/10) without any other detail visible.
North Temperate Belt (NTB): Appears dark to dusky (3-4/10) and broad.
North Temperate Zone (NTZ): Appears shaded to bright (6-7/10).
North Polar Region (NPR): Appears dark to dull (3-5/10) and mottled.
The best of luck in your own imaging and observations of Jupiter.
Regards,
Carlos E. Hernandez
Martian's attachment for post 31670
