Late Sunday Night Mars, 2003/8/11 UT
Started by Dave Mitsky, 08/11/2003 06:22AM
Posted 08/11/2003 06:22AM Opening Post
After a well-attended public observing session at the Naylor Observatory - see http://www.astrohbg.org - came to an end a few of us stayed to observe Mars with our 17" f/15 classical Cassegrain. The weather had been mostly poor earlier in the evening and hadn't improved much in the meantime but Mars was nicely visible nevertheless through occasional thin clouds. The seeing was rather good for the most part, perhaps in partial compensation by the weather gods for the poor transparency. We were able to view Mars until a bit after 05:20 UT when the presence of lightning in the distance suggested that closing the dome might be a wise decision.
At 04:25 UT the CM was 199 degrees. The SPC was noticeably smaller than the last time I had seen it (2003/7/31 UT). Mare Sirenum, Mare Cimmerium, Hesperia, and a trace of Mare Tyrrhenum I believe collectively resembled a wishbone spanning the planet, running horizontally across the field of view. A bright Hellas was apparently making it presence known on the following (eastern) limb.
Magnifications of 218, 249, 259, 324, and 404x were used along with a number of color filters including Wratten #21, #25, #30, and #80A.
Dave Mitsky
