Lulin, the moon and Venus
Started by jonisaacs, 03/09/2009 02:29PM
Posted 03/09/2009 02:29PM Opening Post
This is just a short observing report...
With the moon nearly full and within 20 degrees of the Comet Lulin, I had not been able to spot Lulin for the past few days. Last night though, Lulin was almost 25 degrees from the moon so even with the moon full, I figured I would give it my best shot, my 16 inch F/4.42 Scopestuff DOB.
One of the challenges of this fast moving comet is that each evening requires me to figure out a new Starhop. Sometimes it is quite easy, was last week as it passed within 2 degrees of the Beehive. However it has moved on now, is more than 7 degrees from the Beehive. Looking at Planetarium on my Sony Clie I noticed that it was almost perfectly centered between two magnitude 5 stars, 16 and 10 Cancer, about two degrees from each. 16 Cancer is a ~6 arc-second mag 5-6 double which makes identification easy.
It took a while to locate the two guide stars as the Moon was washing out the finder and the dew had taken it's toll on the Telrad but once I able to identify my guide stars, I was able to position the scope and the core of Lulin was there to be seen, very faint and barely perceptible but it was there... I used the 22Pan (94x with a 4.3 mm exit pupil) After locating it I tried a variety of eyepieces ranging from 35mm to 12mm, except for the size, not much change, barely perceptible...
Anybody else catch Lulin last night?
Venus, it is at it's best, a thin crescent that has been visible as a crescent in my 10x50's for the last week or so. It's over 50 arc-seconds in diameter. In the 16 inch DOB it's quite spectacular.
