The red planet Mars is now prominent in our evening eastern sky. It reached its western quadrature 90° from the Sun on 2007 SEP 17 and will rise this evening (NOV 24) at 18:46 CST for Chicagoland observers. Today it is at a distance of 0.644 AU with a diameter of 14.5 arcseconds and 96% of its apparent disk illuminated at magnitude -1.2. It’s currently brighter than all stars visible from mid-northern latitudes except for Sirius.
On NOV 15 Mars started its apparent retrograde motion as Earth began sweeping past it. The loop that will be formed is demonstrated in my graphic of the current Mars apparition. To see it, click:
http://www.curtrenz.com/astronomical.html
Mars closest approach for this apparition will occur on DEC 18 at 0.58933 AU, which is considerably further than the extremely favorable approach in 2003 of 0.37272 AU. Its angular diameter on DEC 18 will be 15.9 arcseconds compared with 25.1 in 2003. Mars’ opposition from the Sun will occur on DEC 24 in longitude, right ascension and elongation. It will then be rising around sunset and setting around sunrise. Its magnitude during the period around opposition will be -1.6, which is slightly brighter than Sirius.
Mars will end its retrograde movement on 2008 JAN 30 and reach eastern quadrature on MAR 30. Eventually it will move into conjunction behind the Sun on 2008 DEC 05.
This year Mars may approach further than in 2003, but its declination of N 26.8° at opposition will be much more favorable for northern hemisphere observers. My diagram illustrating the positions of Mars, Earth and Sun at oppositions from 2003 to 2018 can be seen at the same link given above. Enjoy your hunt for Martians!
For astronomical graphics, including
monthly wallpaper calendar, visit:
CurtRenz.com/astronomical
Curt Renz
