Mars Magnification?
Started by pjbilotta, 06/09/2003 04:36PM
Posted 06/09/2003 04:36PM Opening Post
Some expert opinions please on appropriate magnification for Mars . . .
Generally, 180x - 220x seem to be the ideal magnification ranges for Jupiter and Saturn in average seeing from my Midwestern locale. From what I have read and observed, the expert opinions suggest that Saturn can bear a higher magnification because of the higher contrast of its limited features.
So, what about Mars? Until my recent increase in aperature to 6", I have never gone much more than 200x on Mars in the past. Do Mars' features bear magnifications higher than this in average seeing (some posts refer to using 300x - 400x), or am I best to stick within the same magnification range for other planetary observing?
Thanks for your feedback.
Posted 06/10/2003 01:36AM #1
For the best view of the south polar cap in 1988, the last good Mars opposition, I used 480x with my 8 inch refractor. The polar cap is a high contrast feature and can tolerate lots of power. For the best view of the dark areas, I found 325x to be optimum. Of course the seeing must be reasonably good. Here in Iowa we occasionally have very good seeing. The minimum magnification I use on the planets (Mars, Jupiter, and Saturn) is 230x. If the image is fuzzy at this power, I close up the observatory.
Posted 06/11/2003 05:57AM #2
Mike,
Mars does indeed look good at magnifications of 400x and above.
Dave Mitsky
