Mars Observation (January 15, 2006)
Started by Martian, 01/15/2006 02:45AM
Posted 01/15/2006 02:45AM Opening Post
I made an observation of Mars on January 15, 2006 (00:20 and 00:45 U.T.) under average seeing conditions (4-5/10, with very brief moments of 6/10). Mare Cimmerium and Mare Tyrrhenum were prominent on the CM. A very bright (8/10) cloud was visible over Hellas. I welcome any comments that you may have on my observation.
Date (U.T.): January 15, 2006
Time (U.T.): 00:20 (left image) and 00:45 (right image)
CM: 245.4 (left image) and 251.4 (right image)
Ls 356.7, De -17.3, Ds -1.4, p 0.90, 10.4"
Instrument: 9-inch (23-cm) F/13.5 Maksutov-Cassegrain
Magnification: 248x and 271x
Filters: Klee OPS Barlow and W38A
Seeing (1-10): 4-5, Antoniadi (I-V): III
Transparency (1-6): 5
Notes.
00:20 U.T. (Left image, CM 245.4, Klee OPS Barlow): An extremely bright (9/10) South Polar Haze (SPH) was visible (the South Polar Cap (SPC) was not visible). Mare Chronium appeared dusky to dull (4-5/10) preceding the CM. Eridania and Ausonia appeared bright (7/10). Hellas appeared very bright (8/10) over the south-following limb. Mare Cimmerium appeared dark to dusky (3-4/10) preceding the CM. Hesperia appeared bright to very bright (7-8/10). Mare Tyrrhenum and Syrtis Minor appeared dark to dusky (3-4/10) following the CM. Syrtis Major appeared dull (5/10) and obscured by very bright to extremely bright (8-9/10) haze over the following (morning) limb. Aeolis, Aethiopis, and Aetheria appeared bright (7/10). The Hyblaeus Extension appeared dusky to dull (4-5/10) on the CM towards the northern limb. Extremely bright (9/10) morning limb haze (MLH), evening limb haze (ELH), and a North Polar Haze (NPH) were noted as well.
00:45 U.T. (Right image, CM 251.4, W38A): Mare Cimmerium, Mare Tyrrhenum and Mare Chronium appeared dusky to dull (4-5/10). A very bright (8/10) cloud (haze) was noted over Electris over the south-preceding limb. A very bright (8/10) cloud (haze) was noted over Hellas over the south-following limb. Extremely bright (9/10) morning limb haze (MLH), evening limb haze (ELH), South Polar Haze (SPH), and a North Polar Haze (NPH) were noted as well.
The best of luck imaging and observing Mars as it becomes smaller in apparent size.
Regards,
Carlos E. Hernandez
Martian's attachment for post 29173
