Altitude, Aperture, and Atmosphere... I increased all three relative to my last view days ago and WOW! The details:
I happened to roll over and see the clock this morning at 4:10; I walked to the glass door but couldn't see outside because it was fogged up (must be humid!) and so took a step outside to see Mars HIGH overhead. After my poor viewing a couple of days ago, I was anxious to get a better view of this side of Mars, and I had already put my 9.25" SCT in the tool shed yesterday evening to be ready for use. I was dressed and had the SCT mounted on the driven CG5 on steel tripod by 4:30 (not bad for having been in bed at 4:10!). After using my 8" f/5 reflector a lot recently, I noticed during setup how pleasant an SCT can be with it's smaller tube mounted HIGHER which leads to less bending for balancing and alignment.
Not being used to photographing with the SCT, indeed being my first Mars photograph with this particular SCT ever, I took three photographs instead of my usual one: 1/5 second exposures at 5 frames per second, 1/10s at 10fps, and 1/25s at 15fps. Even with the extra exposures, I was completely done with the photographing and had the computer packed up again by 4:50. Already I was really excited since the view on the screen was SOOOOO much nicer than my view 3 days ago, which had Mars about 20 degrees lower in a much murkier sky.
While the computer was doing it's thing, I got to spend some time staring at the sky since the Perseids are peaking today. I did get to see one bright meteor streaking down toward the Eastern horizon, not bad I guess for my light-polluted yard. This was the only one observed during my cumulative skygazing of maybe 3 minutes.
I immediately went to putting in the binoviewer which I yesterday reconfigured for 2x use instead of the 4x configuration I had been using for the f/5 Newt. This is really convenient since I get similar power with the same eyepieces in both scopes since both systems effectively run at f/20 (f/5 x 4, or f/10 x 2). The 11mm Plossls were too much power at 440x, but the 15mm's seemed just right at 320x.
My first impression was shock and amazement: Sinus Sabaeus just popped out so clear and immediate I thought it was my imagination. It was clearly separated from the Erythraeum/Margaritifer area, and even more surprising was that dark Oxus extension coming down from Margaritifer. Niliacus Lacus also showed up nicely next to the blue north polar hood. All this from a still very small disk since opposition's still 3 months away! During sketching I did also notice some more mottling at the Chryse edge of Margaritifer Sinus, while continuing to be surprised whenever Oxus popped clearly into view again. Niliacus Lacus continued to be surprisingly muted; possibly the NPH extended further than it's obvious portion to where it slightly obscured features further out.
A couple more closing comments about the SCT, since it was it's first planetary use for a while: the viewing position is really noticably more comfortable than with the Newt, but the mushy focusing is aesthetically distateful although it does not detract from the final view. Also, I was disturbed when unmounting the SCT at 5:10 that it was badly dewed up, to the point where some larger drops were starting to form; I have NEVER seen dew on my Newt's primary or secondary! This would have caused me to have to put on the dew control strips if I had planned on observing longer, but this time caused me no problem since I took it inside the cooler house immediately and left the cover off so the dew could dry (which it did within minutes). But I'll cut it some slack this time since it was really damp tonight, which I had noticed by the fog on the window before even going out!
