Elusive Mercury is about to begin a fine apparition as the lesser Evening Star following its Superior Conjunction behind the Sun on January 6. It will be joining its big sister Venus in the western sky after sunset. Mercury will achieve its Greatest Eastern Elongation of 18.2° on February 7. Its greatest altitude as seen from Chicago thirty minutes after sunset will be 10.8° on February 8. It will then dive toward Inferior Conjunction between the Earth and Sun on February 22. Mercury’s stellar magnitude is currently about –1 and will steadily dim to greater than +2 before it leaves the evening sky about a month from now. By contrast, Venus is currently shining at –3.9.
I’ve created a graphic that demonstrates Mercury’s position in Chicago’s western sky thirty minutes after sunset from now through February 19. Although the diagram should well serve most northern hemisphere observers. To see it, click: http://www.curtrenz.com/astronomical.html
For astronomical graphics, including
monthly wallpaper calendar, visit:
CurtRenz.com/astronomical
Curt Renz
