During the night of 2006 FEB 5/6 the Moon will occult many of the stars in the Pleiades cluster (M45) in Taurus for observers in Hawaii and western North America. It should be a pretty sight. The apparent disk of the waxing gibbous Moon will be 60% illuminated. Therefore, occulted stars will disappear behind the Moon’s dark limb and reappear from its bright limb. The northern graze path for the third brightest Pleiades star, Mag 3.7 Electra, will pass through Los Angeles.
To see my occultation graze map, click:
http://www.curtrenz.com/astronomical.html
Observers located on a star’s graze path will see that star winking on and off as hills and valleys on the lunar limb pass by. A graze path is roughly as wide as the difference in elevation between the lunar topographic features, generally a couple of kilometers. Those observers located north of a star’s southern graze path and south of that star’s northern graze path will witness a full occultation. The distance between the two graze paths is at least as great as the polar diameter of the Moon, 3472 kilometers. In some cases only one of the graze paths exists, because the other would be in outer space above a polar region.
The graze paths for each of the seven brightest Pleiades stars are plotted on my map. Below the stars’ apparent coordinates are for the date of the event (not 2000.0):
RA 03:47:50.9 Dec N 24°07’35” Mag +2.9 Alcyone
RA 03:49:31.3 Dec N 24°04’28” Mag +3.6 Atlas
RA 03:45:14.7 Dec N 24°08’05” Mag +3.7 Electra
RA 03:46:11.5 Dec N 24°23’21” Mag +3.9 Maia
RA 03:46:41.4 Dec N 23°58’11” Mag +4.2 Merope
RA 03:45:34.3 Dec N 24°29’19” Mag +4.3 Taygete
RA 03:49:33.1 Dec N 24°09’27” Mag +5.0 Pleione
Southern Californians take special note. The northern graze path for Electra will pass through your area, including the city of Los Angeles. Those on the path will witness a graze. Those south of the path will see a full occultation.
Below is my graze interpolation algorithm for Electra, which is accurate between 114° and 122° of western longitude but not outside those limits. The results should be rounded to no more than four places after the decimal point. The only input value is the western longitude. All values are decimal, including the hours. The Zenith Angle is the position of the star on the lunar limb measured counter-clockwise from the Zenith.
W = Western Longitude (input)
N = Northern Latitude (output)
H = Hours PST (output)
Z = Zenith Angle (output)
L = W – 118 (L is a negative value when W is less than 118)
N = 33.8749826 + 0.38708718 L – 0.00320651 L²
H = 0.1608787 – 0.00867207 L – 0.00023953 L²
Z = 292.7329 - 0.03015 L + 0.000286 L²
Please reply within this thread to receive specific occultation or graze data for your location. I’ll need your Longitude, Latitude, Time Zone, approximate Altitude above sea level, and the name of the stars that interest you. If your desire is to find the latitude for a certain star’s graze point that matches a specific longitude, please say so.
For astronomical graphics, including
monthly wallpaper calendar, visit:
CurtRenz.com/astronomical
Curt Renz
