Online Transit Observing info
Started by kmichaelm, 06/07/2004 07:52PM
Posted 06/07/2004 07:52PM Opening Post
Stuff that I'm sure we all know, but in case you want some URLs you can throw at someone... mike
Webcasts of the Transit of Venus:
http://skyandtelescope.com/observing/objects/article_1258_1.asp#WEB
http://www.xs4all.nl/~carlkop/venus/transit.html
Where you can see the Transit of Venus:
http://skyandtelescope.com/observing/objects/planets/article_1021_1.asp
Your Guide to the Transit of Venus
There are many ways to dim the sun's light that may appear to be safe but *still* let through dangerous amounts of infrared and ultraviolet radiation that can cause severe, permanent eye damage.
Unless you are properly using filters specifically manufactured for solar observing, you are putting your eyesight at great risk. If you don't have such equipment, see the web site below and use the "Projection" method. That is safe if done carefully.
http://skyandtelescope.com/observing/objects/sun/article_1260_2.asp
"...Filters that are not safe, though sometimes recommended in error, include smoked glass, stacked sunglasses, crossed polarizing filters, neutral-density camera filters, metallized candy wrappers, and compact discs. While these may greatly dim the Sun’s glare, invisible radiation may get through and damage your eyes. And don’t use a camera with a telephoto lens, even if the lens has photographic filters on it that appear to darken the Sun. "
Safe solar observing:
http://skyandtelescope.com/observing/objects/sun/article_1260_1.asp
http://skyandtelescope.com/observing/objects/sun/article_94_1.asp
http://skyandtelescope.com/observing/objects/sun/article_101_1.asp
Eye Safety And Solar Eclipses:
http://umbra.nascom.nasa.gov/eclipse/990811/text/eye-safety.html
2004 and 2012 Transits of Venus;
http://sunearth.gsfc.nasa.gov/eclipse/transit/venus0412.html
Other info on the Transit of Venus:
http://sunearth.gsfc.nasa.gov/sunearthday/2004/index_vthome.htm
http://sunearth.gsfc.nasa.gov/eclipse/OH/transit04.html
http://www.exploratorium.edu/venus/ (live webcast here)
local predictions can be found at:
http://sunearth.gsfc.nasa.gov/eclipse/transit/TV2004.html
