Sculptor Galaxy (NGC 253)
Planetary Eyepiece (Part 2)
Started by Martian, 03/08/2003 12:09PM
Posted 03/08/2003 12:09PM Opening Post
Eye Relief:
The distance between the outer (or eye) glass lens and the observer's eye in which the entire field produced by the eyepiece is visible. This is an important consideration as a small eye relief (<5mm) becomes frustrating and more importantly produces fatigue in the eye of the observer while monitoring the planet for delicate detail. Some manufacturers have improved this factor by placing a barlow lens before the inner (or field) lens (e.g. Lanthanum eyepiece with a 20 degree eye relief). A quality barlow (e.g. 2x Ultima) coupled with a medium focal-length eyepiece (e.g. 12-18mm) can provide adequate eye relief at higher magnifications.
The above are vital factors that must be considered in the purchase of an eyepiece to be used for planetary observation.
The following are secondary factors that must also be considered in the purchase of an eyepiece;
5) Apparent field of view
6) Cost ($)
7) Weight (of the eyepiece)
I personally use the University Optics Abbe Orthoscopic, Zeiss Abbe Orthoscopic, Televue Plossl, Apogee Easy-View, and Meade Ultra-wide in my planetary observations. I would like to hear from other observers what their experiences are with different designs and brands of eyepieces.
Respectfully,
Carlos E. Hernandez
Posted 03/08/2003 02:26PM #1
Carlos,
Have you tried the type 6 Naglers? Many observers, myself included, have found them to be excellent for planetary work as well as deep-sky observing. (In fact, I am considering selling my 8mm Radian to partially finance the purchase of a 5mm type 6.)
I once owned a 6.7mm Meade UWA (the original version) but never felt it was a particularly good planetary eyepiece. Neither was the 7mm Nagler type 1, IMO, that eventually replaced it. However, I was very pleasantly surprised with the performance of the 7mm type 6 that I purchased at the NEAF last year.
I've also used or own U.O. orthos, Tele Vue Ploessls, Brandons, Pentax SMC orthos and XLs, Zeiss Abbe orthos, Orion Lanthanum Superwides, and Takahashi LEs. The Zeiss and Pentax orthoscopics were very impresssive indeed.
Dave Mitsky
