Saturn: do the rings ever align parallel to sunli
Started by Steven lynn, 10/16/2006 08:41AM
Posted 10/16/2006 08:41AM Opening Post
If you haven't seen this, check it out!
http://photojournal.jpl.nasa.gov/catalog/PIA08329
This made me wonder of the view of the rings from the non-existent solid surface of Saturn. Maybe Saturnians have the opposite of scuba diving, and don suits and gear to float above the dense gases.
My thought was: do the rings ever align parallel to the rays of sunlight, so the sunlight is lighting the rings edge on. This is not to be confused with the appearance to us on earth, as every so many years the rings appear edge on and almost disappear.
If the rings do line up parallel to sunlight, then will the rings be lit up less by the sun? We'll call this a ring crossing event, just to give it a name.
If this happens, I'm guessing it would occur every 15 years and 3 months, or twice for each Saturn 'year' or 29.5 years. When the rings are closest to parallel to the light rays from the sun, some of the ring material will be in the shadow of other ring material, and the rings will be 'lit' up less than usual. The material at the edge closest to the sun wold be lit up, but would the outer material cast a shadow dimming ring material in the shadow? I'm guessing the rings as seen from Saturn will slowly dim for several days or weeks, becoming noticeably less bright but no-where near completely dark. I have no idea if the event would last hours, days, weeks, or even months.
Also, the rings may be lit up unevenly, showing different structure than usually seen. The rings are not 100% flat, but have some sections that are tilted in relation to other areas, or have 'bumpy' or wavy areas. Just like sunlight will hit mountain peaks during sunrise or sunset, these areas of the rings will be lit-up more than other areas during the crossing event.
Another thought. It appears from the pics in the link above that the back side of Saturn and the rings behind the planet are also visible. Artistic license, or do the rings reflect light on the back side of Saturn and the rings behind the planet, just like moonlight? And if so, is the amount of light substantial or faint?
For more fun, search out the book “What if there were no moon?” By Steven Parker
The only thing wrong with censorship is [deleted].
Posted 10/16/2006 04:47PM #1
Hi Steven,
The rings orbit directly about the equator of Saturn, so they would be edge-on to the Sun during the equinox on Saturn.
Cheers,
Maurice
Posted 10/16/2006 05:38PM #2
Yes indeed, it would happen twice every Saturnian year at its equinoxes, since the rings are right over Saturn's equator, as Maurice noted. However, since Saturn's orbit is eccentric, the separations between equinoxes alternate between 15 years 9 months and 13 years nine months. The next equinox for Saturn will occur on 2009 AUG 10. The Earth will pass through the plane of Saturn's rings on 2009 SEP 04. The following equivalent dates are 2025 MAY 06 and 2025 MAR 23. It’s estimated that the rings will seem to disappear for earthbound observers for about 25 days in 2009 and 44 days in 2025.
Since the rings are so thin, an observer on the equator of Saturn at the equinox would only see a stripe across the Sun. The observer would be in the penumbra of the ring particles, not the umbra. So in effect it would be a partial eclipse with most of the sunlight coming through. However, for an observer on the inner edge of the ring there would be substantial blocking of sunlight since he would be in the umbra of individual or groups of particles.
Since the rings are made of countless small satellites, they would shine in the nighttime sky for an observer on the "surface" of Saturn just as the Moon does for us. However, they will often be eclipsed by Saturn's shadow in the manner of a lunar eclipse. wink
For astronomical graphics, including
monthly wallpaper calendar, visit:
CurtRenz.com/astronomical
Curt Renz
Posted 10/17/2006 08:04AM #3
Thanks for your replies. Maybe in a couple of hundred years Virgin spaceways will be offering 'ring eclipse' tours.
SL
