I assume you mean only events visible from southern California in 2006. If so, no solar eclipses, lunar eclipses nor occultations of planets by the Moon will be seen in your region.
As has been noted, there will be a transit of Mercury across the face of the Sun on November 8th. On August 26th Venus will appear to pass Saturn by only 4 arcminutes.
The brightest asteroid, Vesta, will be in opposition to the Sun on January 7th at magnitude 6.2. Saturn will reach opposition on January 27th. Jupiter’s opposition will come on May 5th. Venus will reach its greatest western elongation on March 25th. Mercury will present its greatest eastern elongations on February 24th, June 20th, and October 17th. Its greatest western elongations will come on April 8th, August 7th and November 25th.
Of special note regarding lunar occultations is a series involving the Pleiades cluster. The first such event in 2006 will occur on January 9th. That evening four of the Pleiades will be occulted in your area, and a fifth (actually the second brightest: Atlas) will create a graze path that passes near you. Observers on the graze path will be able to watch Atlas winking on and off as lunar hills and valleys pass by. You’ll have more opportunities to witness the Moon moving through the Pleiades on February 5th, October 9th and December 3rd. Click the following link for graphics I’ve created related to the January 9th event: http://www.curtrenz.com/astronomical.html
