Early Tuesday morning the old crescent Moon, Jupiter, and Venus formed a striking celestial dogleg. As the morning progressed, the Moon closed the gap with Jupiter on the way to crossing paths with the King of Planets.
Two fellow ASH members and I were fortunate enough to witness the occultation of Jupiter from the ASH Naylor Observatory. To do so we had to dodge the fair weather clouds that littered the sky and nearly occluded the occultation.
Instruments used were a 5" f/5 achromatic refractor, an 8" f/6 Hardin Dob, a 12.5" f/6.5 Cave Newtonian, and a 17" f/15 classical Cassegrain.
I saw the Moon grow close to the planet through the 17" and 5" and watched the actual event through the 12.5" and the 8", using primarily a 26mm Tele Vue Ploessl (79x) and a 20mm Meade Wide Angle (66x) respectively. Seeing Jupiter being consumed gradually by the lunar surface beginning at 11:05 a.m. EST (16:05 UT) was a blast. The Galilean satellites were not visible, of course.
While we waited for Jupiter to reappear, we observed the Sun through an 8" Celestron Orange Tube SCT, a 2" generic 32mm Erfle, and a full aperture Orion glass solar filter. The large active region AR 10696 was quite impressive and was large enough to be seen without optical aid but otherwise the sun seemed to be devoid of sunspots.
The clouds were not so kind for the reemergence of Jupiter at 12:09 p.m. EST (17:09 UT) but I did catch it about 6 minutes later through the 5" achromat and a 16mm Brandon.
When it comes to daytime planetary occultations I suppose seeing half of one isn't too bad.
Before I left the observatory I viewed the Moon, which was by then far to the southwest, and Venus through the 5" and the 17" and a 55mm University Optics Ploessl (118x) but I couldn't locate Jupiter.
Dave Mitsky
Dave Mitsky
