As we hear in the media that yet another year is setting global warming temperature records, here's an article from Forbes that summarizes what I've been saying for years: the 'corrected' data is phony. Always look to raw thermometer readings in rural areas first if you are at all worried about global warming.
“Americans just lived through the hottest 12 months ever recorded, the National Oceanic and Atmospheric Administration reported Tuesday,” according to the May 15 Los Angeles Times.
Which begs the question, what does “recorded” mean?
To most people, the hottest temperatures ever “recorded” would imply that quality controlled thermometers registered higher readings during the past year than had ever occurred before. If you believe that this is what the National Oceanic and Atmospheric Administration (NOAA) means by hottest temperatures ever “recorded,” then you are wrong.
Raw temperature data show that U.S. temperatures were significantly warmer during the 1930s than they are today. In fact, raw temperature data show an 80-year cooling trend. NOAA is only able to claim that we are experiencing the hottest temperatures on record by doctoring the raw temperature data.
Doctoring real-world temperature data is as much a part of the alarmist playbook as is calling skeptical scientists at Harvard, Princeton, Columbia, MIT, NASA, NOAA, etc., “anti-science.” Faced with the embarrassing fact that real-world temperature readings don’t show any U.S. warming during the past 80 years, the alarmists who oversee the collection and reporting of the data simply erase the actual readings and substitute their own desired readings in their place. If this shocks you, you are not alone.
The bureaucracy at NOAA and NASA who report the U.S. temperature data undertake what they term “correcting” the raw data. These corrections are not just one-time affairs, either. As time goes by, older temperature readings are systematically and repeatedly made cooler, and then cooler still, and then cooler still, while more recent temperature readings are made warmer, and then warmer still, and then warmer still.
Ironically, the government overseers of raw temperature data are doing just the opposite. As Goddard shows here, they are doctoring older temperature readings (when urban heat island effects were minimal) in a manner that makes the older temperature readings seem colder than was reported in the real-world data. At the same time, they are doctoring more recent temperature readings (when urban heat islands are more pronounced) in a manner that makes the more recent temperature readings seem warmer than the real-world data report.
The real-world U.S. temperature data show a long-term cooling trend. Common sense indicates that if the real-world data need adjustment, the proper adjustment is to further reduce recent temperature readings. Yet the bureaucrats who oversee the data have instead doctored the data to show a false, long-term warming pattern.
http://www.forbes.com/sites/jamestaylor/2012/06/13/doctored-data-not-u-s-temperatures-set-a-record-this-year/
