Here's an interesting chart I just put together - it's a plot of 12 month averages of the Southern Oscillation Index and de-trended RSS temperatures. It's interesting to note how close the ups and downs match up except for the Chichon and Pinatubo eruptions which are marked.
So, when skeptics like to make hay about temps have flattened or dropped since 2003 (or whenever) notice what the SO index was doing. Then consider that we just entered ENSO neutral conditions (neither EL Nino or La Nina) after being in a La Nina and may enter El Nino conditions soon (May's SO index was -5.1 which would be 5.1 on the chart) - so what will the temps do then?
Now, before the skeptics get all excited and try to say "see - its ENSO and not CO2 driving temps" I'll point out that the RSS data has had the trend of about 0.0013 C removed per month (0.0013 for the 1st month, 0.0026 for the second month, etc up to about 0.4684 removed for April 2009). The ENSO data is unaltered because it has no trend (Dave - that means it's "flat"). So the correlation we are seeing here is correlation with the wiggles in the trend, but not correlation with the trend.
I didn't do anything fancy here, it was very simple:
- Reverse the sign of the SO index so that El Nino conditions are positive and La Nina conditions are negative.
- Calculate the per-month slope of the RSS data and subtracted that times the months from the start from the RSS data. This removes the trend from the RSS data so what we have is the variation from the trend (Dave - that makes it "flat").
- Average every 12 month span (01/1979 to 12/1979, 02/1979 to 02/1980 etc)
The ENSO data is from here:
ftp://ftp.bom.gov.au/anon/home/ncc/www/sco/soi/soiplaintext.html
With a brief explanation here:
http://www.bom.gov.au/climate/glossary/soi.shtml
The RSS data is here:
http://www.remss.com/data/msu/monthly_time_series/RSS_Monthly_MSU_AMSU_Channel_TLT_Anomalies_Land_and_Ocean_v03_2.txt
