A study in print in the Journal of Geophysical Research - Atmospheres:
On the reliability of the U.S. Surface Temperature Record
http://www1.ncdc.noaa.gov/pub/data/ushcn/v2/monthly/menne-etal2010.pdf
analyzed the stations as ranked by Anthony Watts' (http://wattsupwiththat.com/) surfacestations.org project comparing both unadjusted and homogenized data from good and poorly sited stations as classified by surfacestations.org. They also cross checked this against the more modern & redundant (multiple instruments at each site) USCRN network.
And they found that the poorly sited stations (a large majority) showed bias ...
So why are the "skeptics" so quite about this? After all, wouldn't this something they'd be all over?
Well, perhaps that's because the poor sites (you know, the ones next to buildings, air conditioners and such that the "skeptics" are always pointing out) showed a cooling bias.
Ooops!
OK - to be clear, the poor stations showed slightly higher minimum temps and cooler maximum temps.
So what's up with that? Well, it turns out that the poor sites are predominancy use MMTS electronic sensors whose relatively short cables required them to be installed near the building where the indoor reading units are located. The good stations mostly use Liquid in Glass (LiG) thermometers - you know, the manually read kind - that didn't require them to be installed near buildings. It is well known that MMTS will read lower than LiGs, that in combination with the fact that when stations switched from LiG to MMTS, they also changed the time of reading from afternoon to morning. These two factors are thought to be the main reason for the bias.
BTW - it's these type of known biases that are why the station data is homogenized - to correct for artificial (non-climatic) changes.
One last item - as much as I give "skeptics" grief, I saw at least one pro-AGW blog (DeSmog Blog) get it wrong here:
Urban Heat Island Myth is Dead
http://www.desmogblog.com/urban-heat-island-myth-dead
This really has nothing to do with the Urban Heat Island (UHI) effect but rather is about micro site influence. UHI is real (and corrected for in - you guessed it - homogenization) caused by large-area urban development. Micro site influence is very localized (a building, parking lot etc).
Ooops!
