Yue Ma
HFG-1
It's Here....!
Started by The Mad One, 05/27/2013 02:42PM
Posted 05/27/2013 02:42PM Opening Post
It's Here!
Well Floyd, I finally got the trike! Actually I received it on the 16th, but there have been some problems and bad luck! It had to go the local dealer here who only special orders the ICE trikes for repair before it was even assembled! The left side brake caliper mount somehow warped when it was welded to the kingpin, bad jig or loose in the jig, at any rate the wheel could not be mounted to the trike until the kingpin was replaced! The bike mechanic checked it out to find the mount point was 15 degrees out of square. ICE expressed the replacement kingpin & I finally managed to have it all setup & picked it up on the morning of the 25th.
I finally got to turn the pedals on it on the 25th, but not very much as I have been having a bad bout of the influenza! I'm feeling a bit better today & should be up to par in a couple more days, hazard of my profession! One gets a lot of exposure in the EMS business, and every once & a while you get zapped regardless of how much BSI you take. Doesn't matter whether I'm on the Engine or the transporting medic, as the ALS provider I still have a lot of direct patient contact! Anyhow She's a beauty & I kind of feel like it has been pre-disastered a bit with all of the delays in getting to ride it. She sits out in the garage now mocking me!! wink
The little time I spent on it checking it out, it was a lot of fun even though I danged near hacked up a lung after the ride! I really like the setup on the Sprint 26 fits me OK, but I don't think I could be another inch wider! Eager to get it out on the road when I am feeling better!
Later!
The Mad One's attachment for post 57488
Posted 05/27/2013 06:02PM | Edited 05/27/2013 06:22PM #1
Nice! 8O You will have a ball on that. I just love mine and ride it as often as I can. grin I have gotten out 3x in the last 5 days. In a while I will go again for a few miles.
It takes a little while to get your recumbent legs. You use different muscles than a regular bike, so take your time. Spin faster, mash less on the pedals. A good cadence is 80-100 rpm. I normally am around 80-85 with max output at 95 or so. Much more than that and I am spinning faster than comfortable.
95 rpm on my trike in high gear is 25 mph and that is pretty fast on the flat. I did this two days ago and it took everything I had to keep it up for a half mile. 15-19 mph is much easier to do and I cruise at those speeds, depending on wind, incline ect.
