Re-entry Heat
Started by Lee_S, 02/01/2007 03:47PM
Posted 02/01/2007 03:47PM Opening Post
Here are my geeky questions of the day:
I recently read an article about a private company that hopes to take passengers up for short space rides in what was described as a 'souped up lear jet.'
Will these private space ventures to take people to the edge of space have to cope with the same sorts of re-entry heat that space capsules and the space shuttle deal with? Or do they deal with far less heat because they re-enter at far lower speeds? And, if the heat is so much less for a low speed reentry, is it possible to slow a spacecraft like the shuttle down enough before it enters the atmosphere so that reentry heat is reduced? 8O
[SIZE="Small"]------------
[/SIZE]
Posted 02/01/2007 05:25PM #1
Hi Lee,
I'm certainly no expert on this subject but I think the discussions are entertaining. I am sure there are some trained physics folks around here who know far more than I.
As long as these private ventures stay within the atmosphere they will not reach speeds that will generate the same heat that a space vehicle experiences during re-entry. However, they may get hot during flight. According to Wikipedia, "the SR-71 Blackbird jet could fly continuously at Mach 3.1 while some parts were above 315°C (600°F)." Of course, once outside the atmosphere,(in space) there is no heating due to the friction of the air.
It is my understanding that the heat of re-entry results from converting the kinetic energy of the space vehicle to heat. This is what provides the necessary braking action to slow the vehicle. It could be done with a rocket engine prior to re-entry but it would take a similar amount of fuel to slow the vehicle as it did to accelerate it in the first place. Also keep in mind that if a space vehicle is not moving forward, it is going to fall straight towards the earth. That might make the landing a little tricky.
dan
Posted 02/02/2007 02:08PM #2
Thanks Jarno and Dan. Your answers make a lot of sense. When I first heard about the commercial passenger spacecraft feathering upon re-entry like a badmitton shuttlecock, I thought it was pretty swift. But, you guys have confirmed that it's actually a little slow! 8)
[/SIZE]
