Shane Yarnall
LDN 1622
A question from a beginner
Started by fblue, 07/31/2007 03:03AM
Posted 07/31/2007 03:03AM Opening Post
Ok, I know this is probably a no brainer, but, when you try to image with a full Moon, do you tend to get a lot of sky light?
I tried to image last night with a little upper level haze and a full Moon and I got a lot of background light in the image, gray sky and all. The images were good except for this.
Also, can light reflect off of a tree and cause this?
Posted 07/31/2007 04:02AM #1
Floyd,
Well, it probably depends on several other factors - focal ratio, exposure time, and target brightness. But yes, in general high haze, full moon, large reflecting object nearby (tree) - all would contribute to raise the background level in the image. And unfortunately, likely not evenly across the frame.
Depending on the object, what can possibly help lower the general background level is narrowband filters. Many on this forum will use a H-alpha filter on emission nebula targets for these conditions.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
