RICHARD COFER
Achieving max resolution
Started by RolandC, 09/21/2009 02:58PM
Posted 09/21/2009 02:58PM | Edited 09/21/2009 04:05PM Opening Post
Hi All,
Testing resolution limits at my site last week, I did some experiments to see how pixel scale affects max resolution. I had seen improvements in the past on small faint objects like the Einstein Cross when I increased my pixel scale.
Amateurs usually opt for faster focal ratios in the belief that it will increase their signal/noise ratio. They also sometimes bin their color data, i.e. shoot the luminance at 1x1 and the color at 2x2, thinking that the luminance will compensate for the lower resolution color data. Sometimes that works when the seeing is not very good, but even under not so great seeing, shooting at 2x2 does degrade the results.
Attached are 3 shots of the core of M13 compared side by side. All shots were taken with my 12" Mak-Cass and ST10XE camera. I stacked an number of short 10 second unguided exposures.
#1 shows pure RGB taken at 1x1 binning. #2 shows 2x2 binning, twice as many exposures in an effort to get better signal/noise. #3 shows the original 1x1 RGB with 20 seconds of luminance added.
Result as you can see, the pure RGB has the highest resolution. You can see many faint stars that are washed out in the 2x2 RGB. Even though the 2x2 binned image has less background noise, and it is twice the length exposure (giving theoretically 4x better signal/noise) it does not have better signal. There are fainter stars in the 1x1 image. The third image shows how adding just a short luminance set (two 10 sec L exposures) improves the background noise dramatically and preserves the resolution.
I like to use the four stars in the short arc on the right side of the core as a guide to the resolution of the core. These images have not been sharpened or processed except for stacking.
Rolando
RolandC's attachment for post 48360
Posted 09/21/2009 03:59PM #1
Hi Rolando,
You're preaching to the choir with me. Per someone's suggestion, I started shooting globulars in RGB, unbinned a while ago, was impressed with the contrary-to-popular opinion results, and use it as my standard protocol for almost all targets now.
Your results put method to my madness.
Incidentally, image number two is labeled "1 x 1 binning" rather than 2 x 2.
dan kowall
Posted 09/21/2009 05:20PM #2
Just out of curiosity...what focal length/ratio were you shooting at?
David
Posted 09/23/2009 02:00AM #3
Hi Roland,
Thanks for the valuable information - As a scientist myself, it's nice to see people like you and Richard providing actual experimental data. By the way, I took your advice for an image of M33 that I'm about to post, binned 1x1 for color channels as well. That being said, I have seen some great images taken with an NP-101 (by Bernhard Hubl for example) in which he bins 2x2 for color data. My ST-10XME is so sensitive that I really don't see the need to bin.
cheers,
Jeff
