Autoguider Reports right-Tracks bad--What's up?
Started by Alex McConahay, 09/24/2006 08:55PM
Posted 09/24/2006 08:55PM Opening Post
Why is my St-4 reporting good tracking, when it is not, apparently, focusing on a star?
Here is the situation.
In several of my astrophotographs I have very short star trails, even though my autoguider (ST-4) reports everything was okeedokee. So, I assumed that I had some kind of slippage between the separate guidescope and the Newt, or slippage in the mirror/secondary.
I always take a dark frame before actually going to Find and Focus and starting a track.
Last night, I was tracking on Triangulum galaxy, and had goods tracking (can't wait to process!!!!).......Then I moved the scope over to M1 to start on that. Got it all set up and focused, and did a Find and Focus on the ST-4 to see if I had a guidestar. Luckily, I did, right about where I needed it (39-48 for those of you who use St-4. It had a brightness of about 27 units if I recall correctly.). I did not bother to take a dark frame, since I had not reset anything in the exposure menu. I had finished with M33, hit Interrupt, moved to M1, and after focusing, etc, hit find and focus.. When I got a usable guidestar result immediately, I simply retrained. My retraining result was good, and so I started the tracking and the exposures. The exposures showed tracking errors (stars slightly elongated which were not there in M33) even though the St-4 was reporting tracking errors of random from +4 to -4--and usually about in the 2-3 range or less--in other words, pretty good tracking from what I am use to. I continued the exposure despite the small tracking errors. I should be able to process them out--and it was 3:00 am.
After an hour (12 x 5 minutes with a DSLR). I forgot to turn the ST-4 off, but moved the scope as I was getting ready to put the scope away. Usually when one does this, the ST-4 squawks because it has lost the guide star. But mine did not do complain at all. It continued to report happily---- tracking errors of one to four units, sometimes less, even though I was turning the scope wherever I wanted. Obviously, it was not reporting on actual results.
What gets me--if It was just reporting a hot pixel, would it not report no tracking errors at all? Why did it track M33 Okay, but have a problem with M1?
Why was I getting a report of good tracking, when it was not, apparently, focusing on a star at all?
